查看: 8985|回复: 4
[求助] ICC中plan_group与bounds的区别?
发表于 2012-7-6 14:55:44 | 显示全部楼层 |阅读模式
在Help中说到
create_plan_group:
This command defines exclusive region-based placement constraints for coarse placement. Plan groups restrict the placement of cells to a specific region of the core area.
create_bounds:
The create_bounds command allows the user to define region-based placement constraints for coarse placement. There are two different types of bounds available:move bounds and group bounds. Move bounds restrict the placement of cells to a specific region of the core area. Move bounds require absolute coordinates to be specified, using the -coordinate option.
Group bounds, on the other hand, are floating region constraints. Cells in the same group bound will be placed within a specified bound but the absolute coordinates are not fixed. Instead, they are optimized by the placer. The -dimension option needs to be specified for a group bound.
想问一下,用create_plan_group设置出来的那个方框的Dimension设置的依据是?然后这个方框的位置可以随意放?是不是一定要放在Core内?是不是可以这样理解,icc为group指定的一堆cell在core中找到一个方框大小的位置,然后根据utilizition来优化布局。
而Bounds设置的方框一定要放在core内,它包含的cell不能跑到设置的方框的外面?
发表于 2012-7-6 20:19:30 | 显示全部楼层
plan_group 侧重于partition概念, hier flow用的多,
bounds 是设一个物理约束,  不一定是hard constraint,
plan——group一定是hard bounds, 反之不是,
发表于 2014-3-7 12:04:42 | 显示全部楼层
回复 2# icfbicfb
   你好,看了下资料里面说plan group是用于hier,create plan group----commit fp plan group
然后对划分的plan group分别进行timing plan,place,clock,route最后generate ILM,FRAM,然后在顶层重组
我在fp里面做了几个plan group,但是没有commit,也没有做timing plan,然后整个design一起做place以及CTS
report timing以及congestion都过了 这样应该还是flatten模式
但是CTS的时候,保持时间违例比较多,也无法优化,clock_opt直接abnormally teminated
created_bound是不是就是用在flatten模式下,floorplan或者placement的时候创建?
我这个相当于是个小型的SOC,有几个硬核,还有另外几个功能模块,我放在了plan group里面
请问下适合用什么方式呢
发表于 2014-11-18 09:40:07 | 显示全部楼层
回复 3# lilyzhong
    问题解决了么?能否分享一下是怎么做的?O(∩_∩)O谢谢
发表于 2014-11-18 10:49:30 | 显示全部楼层
    create_plan_group是基于logic module建的,没有固定区域, bound就是把cell圈在一起
GMT+8, 2025-10-5 02:28 , Processed in 0.017514 second(s), 6 queries , Gzip On, Redis On.
