查看: 9159|回复: 4
[求助] quartus调用modelsim的时候出问题了
发表于 2012-7-4 15:49:00 | 显示全部楼层 |阅读模式
调用的时候出的问题如图所示。
然后打开了.rpt文件,内容如下:
Info: Start Nativelink Simulation process
Error: You did not generate the simulation model files or you generated the IP file using an older version of MegaCore which is not supported by RTL NativeLink Simulation
Error: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode:  NONE
Nativelink TCL script failed with errorInfo:  Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
    (procedure "get_ip_info" line 1)
    invoked from within
"get_ip_info $full_file_name"
    (procedure "run_eda_simulation_tool" line 132)
    invoked from within
"run_eda_simulation_tool eda_opts_hash"
谁能告诉我问题出在哪
发表于 2012-7-10 22:41:33 | 显示全部楼层
感觉像是quartus版本太旧,可能不支持比较新系列的芯片,所以在生成Ip核模型不支持modsim仿真。
不知道你的quartus 版本是什么,使用的又是几系列的芯片?
发表于 2013-10-24 23:03:26 | 显示全部楼层
大哥,小弟遇到和你一样的问题了!!一年之后了,赶紧上线啊!!求指教,一定不是软件的事!!
发表于 2013-11-5 18:02:57 | 显示全部楼层
这个好像是IP核要重新生成以下就可以了。
发表于 2015-8-17 14:51:15 | 显示全部楼层
就是生成FIR的IP宏时没办法生成仿真文件,LZ的这个问题是怎么解决的啊???
GMT+8, 2025-12-26 09:47 , Processed in 0.020100 second(s), 8 queries , Gzip On, Redis On.
