查看: 9382|回复: 13
[求助] DC综合后仿真问题求教
发表于 2012-7-4 15:48:59 | 显示全部楼层 |阅读模式
小弟想用一个简单的实例来实战一下综合后仿真的步骤,但在后仿的时候遇到一下问题,请各位大侠指点一下。二分频实例
module half_clk(reset,clk_in,clk_out);
input clk_in,reset;
output clk_out;
reg clk_out;
always@(posedge clk_in)
begin
if(!reset)  clk_out=0;
else  clk_out=~clk_out;
end
endmodule
综合后的网表为
module half_clk ( reset, clk_in, clk_out );
  input reset, clk_in;
  output clk_out;
  wire   N4, n14, n16;
FFDHD1X clk_out_reg ( .D(N4), .CK(clk_in), .Q(n16), .QN(n14) );
  INVCLKHD8X U7 ( .A(n14), .Z(clk_out) );
  NOR2B1HDLX U8 ( .AN(reset), .B(n16), .Z(N4) );
endmodule
综合过程没有出现voilations,
通过DC导出来的SDF延时文件
(DELAYFILE
(SDFVERSION "OVI 2.1")
(DESIGN "half_clk")
(DATE "Wed Jul  4 00:14:57 2012")
(VENDOR "smic18_ff")
(PROGRAM "Synopsys Design Compiler cmos")
(VERSION "B-2008.09")
(DIVIDER /)
(VOLTAGE 1.62:1.98:1.98)
(PROCESS "worst:best:best")
(TEMPERATURE 125.00:0.00:0.00)
(TIMESCALE 1ns)
(CELL
  (CELLTYPE "half_clk")
  (INSTANCE)
  (DELAY
    (ABSOLUTE
    (INTERCONNECT reset U8/AN (0.000:0.000:0.000))
    (INTERCONNECT clk_out_reg/Q U8/B (0.000:0.000:0.000))
    (INTERCONNECT clk_out_reg/QN U7/A (0.000:0.000:0.000))
    (INTERCONNECT U8/Z clk_out_reg/D (0.000:0.000:0.000))
    (INTERCONNECT clk_in clk_out_reg/CK (0.000:0.000:0.000))
(CELL
  (CELLTYPE "NOR2B1HDLX")
  (INSTANCE U8)
  (DELAY
    (ABSOLUTE
    (IOPATH AN Z (0.133:0.100:0.100) (0.101:0.073:0.073))
    (IOPATH B Z (0.107:0.077:0.077) (0.057:0.041:0.041))
(CELL
  (CELLTYPE "INVCLKHD8X")
  (INSTANCE U7)
  (DELAY
    (ABSOLUTE
    (IOPATH A Z (1.031:0.763:0.763) (1.135:0.806:0.806))
(CELL
  (CELLTYPE "FFDHD1X")
  (INSTANCE clk_out_reg)
  (DELAY
    (ABSOLUTE
    (IOPATH (posedge CK) Q (0.287:0.219:0.219) (0.300:0.219:0.219))
    (IOPATH (posedge CK) QN (0.315:0.240:0.240) (0.294:0.215:0.215))
  (TIMINGCHECK
    (WIDTH (posedge CK) (0.153:0.153:0.153))
    (WIDTH (negedge CK) (0.184:0.184:0.184))
    (HOLD (posedge D) (posedge CK) (-0.052:-0.039:-0.039))
    (HOLD (negedge D) (posedge CK) (0.044:0.038:0.038))
    (SETUP (posedge D) (posedge CK) (0.097:0.071:0.071))
    (SETUP (negedge D) (posedge CK) (0.074:0.052:0.052))
把DC综合后的网表和smic18.v库文件、test测试文件、加载.sdf文件之后出现一下错误
# Loading instances from E:/EDA/KETI_WORK/work/half_clk/half_clk1.sdf
# ** Error: (vsim-SDF-3250) E:/EDA/KETI_WORK/work/half_clk/half_clk1.sdf(20): Failed to find INSTANCE 'U7'.
# ** Error: (vsim-SDF-3250) E:/EDA/KETI_WORK/work/half_clk/half_clk1.sdf(18): Failed to find INSTANCE 'U8'.
# ** Error: (vsim-SDF-3250) E:/EDA/KETI_WORK/work/half_clk/half_clk1.sdf(19): Failed to find INSTANCE 'clk_out_reg'.
# ** Error: (vsim-SDF-3894) : Errors occured in reading and resolving instances from compiled SDF file(s).
# Loading work.udp_dff
# ** Fatal: SDF files require Altera primitive library
#    Time: 0 ps  Iteration: 0  Instance: /top_test File: E:/EDA/KETI_WORK/work/half_clk/top_test.v
# FATAL ERROR while loading design
# Error loading design
请问以上错误是什么原因,我只加载网表之后,有波形出来,波形跟前仿结果一样,但同时加载SDF文件后,就出现ERROR loading design,请各位大侠指点一下,多谢了、
发表于 2012-7-4 17:36:04 | 显示全部楼层
是不是$sdf_annotate参数里那个instance name写错了
 楼主| 发表于 2012-7-4 19:10:56 | 显示全部楼层
回复 2# bukubuku
   啥意思呢?能解释清楚一点吗?在哪里改这个参数呢?求再赐教,多谢了
发表于 2012-7-22 16:09:12 | 显示全部楼层
综合后仿真要读入标准单元的.v文件
发表于 2013-1-27 11:36:49 | 显示全部楼层
学习一下
发表于 2013-2-1 08:59:01 | 显示全部楼层
附上仿真脚本吧
发表于 2013-4-10 10:50:24 | 显示全部楼层
我也遇到了相同的问题,求高手解答!
发表于 2014-5-27 23:34:48 | 显示全部楼层
综合后的网表仿真 太难搞了
发表于 2014-8-21 19:06:08 | 显示全部楼层
学习一下
发表于 2015-10-23 14:55:53 | 显示全部楼层
不錯的訊息 謝謝分享
GMT+8, 2025-11-1 05:44 , Processed in 0.031218 second(s), 5 queries , Gzip On, Redis On.
