查看: 7933|回复: 18
[原创] 加州洛杉矶关于45nm的高速ADC论文
发表于 2012-6-27 10:49:03 | 显示全部楼层 |阅读模式
In this thesis, a SoC (system on chip) solution is proposed for the IF (intermediate frequency) band signal processing and transmission of a radiometer system. This highly integrated and low-power solution is designed for systems where low ADC resolution (< 2-bit) is needed but high-speed data transmission (> 10Gbps) and low-power operation (< 10mW/channel) is strongly desired.
The presented solution includes an array of 2-bit ADCs with duty cycle controlled AGC (automatic gain control) function and a low-power 32:1 serializer. AGC function isincluded in the front end in order to cope with the wide range of input power (-10dBm ~ -20dBm). The AGC loop is controlled by digitized output duty cycle with an error of 2%. A current steering 5-level tree architecture serializer is designed to achieve a high serializing factor and low-power operation.
The circuit is designed using a 45nm SOI CMOS technology. It is capable of digitizing the IF signals using a power of 5.4mW/channel and transmitting the signals at 32Gbps. The serializer has an output reflection (S22) of less than -10dB from DC to 32GHz with 400mV differential output swing. The serializer consumes less than 50mW of power (3.2mW/channel), and the AGC loop consumes 2.2mW/channel.
TABLE OF CONTENTS
1 Introduction ………………………………………………………………… 1
1.1 Research Motivation …………………………………………………... 1
1.2 Organization of Thesis ………………………………………………… 3
2 Research Challenge…………………………………………………………. 5
2.1 AGC Loop Design Challenge…………………………………………….5
2.2 High-Speed Data Transmission Design Challenge……………….………12
3 Proposed Approach…………………………………………………….…..... 14
3.1 SOI 45nm CMOS Technology……………….…………………………..14
3.2 Overview of the Proposed System on Chip……….……………………. 16
3.3 Significance of Innovation ……………………………………………. 17
3.4 Potential Application …………………………………………………. 18
4 AGC Loop Design and Simulation…………………………………………. 19
4.1 VGA Design and Simulation ……….……….………………………… 19
4.2 2-bit ADC Design and Simulation……………………………………… 25
4.3 Duty Cycle Control Design and Simulation…………………………… 30
4.4 Charge Pump (OTA) Design and Simulation…………………………… 35
vi
4.5 AGC Loop Performance…………………….…………………………… 39
5 32:1 MUX Design and Simulation…………………………………………. 42
6 Conclusion…………………………...………………………………………. 46
References …………………………………………………………………….... 47
A 2bit 1Gsps ADC Array with 32 1 Serializer in 45nm CMOS SOI technology.zip (3.24 MB , 下载次数: 198 )
发表于 2012-6-27 20:36:59 | 显示全部楼层
很不错的论文,非常感谢楼主!
发表于 2012-6-28 08:46:35 | 显示全部楼层
感谢楼主。。。
发表于 2012-6-28 20:16:57 | 显示全部楼层
good,thx
发表于 2012-6-29 21:30:54 | 显示全部楼层
kankan,xiexie...
发表于 2012-6-30 17:51:08 | 显示全部楼层
希望是好的。
发表于 2012-7-13 16:17:00 | 显示全部楼层
3xsharing
发表于 2012-7-13 19:34:28 | 显示全部楼层
kankan
发表于 2012-7-18 21:04:28 | 显示全部楼层
duoxie
发表于 2012-8-20 09:58:54 | 显示全部楼层
回复 1# fenglingke
   bucuo,xiexielouzhu
GMT+8, 2025-12-17 00:39 , Processed in 0.030501 second(s), 6 queries , Gzip On, Redis On.
