查看: 5653|回复: 2
[资料] EMCos PCB Vlab
发表于 2012-6-24 11:07:03 | 显示全部楼层 |阅读模式
Is anyone use this software before??
If yes, would you please share the valuable experience on RLC parasitic extraction for PCB layout.
By the way, I don't have a workable license, hence the software can't be launched succesfully.
Detail information for EMCos PCB Vlab is listed below
Detailed introduction cen be found at http://www.emcos.com/PCBVL
which can be download at http://hi.baidu.com/qiuckstar/item/106361ceee82f82d4494165f
No license is found so far
 楼主| 发表于 2012-6-26 23:53:45 | 显示全部楼层
回复 1# willy0130
    I'd gotten a trial license with full features but works only within limited duration and restricted for specific host ID. Can someone help to crack that software??? thanks!! I can provide RMB $500 for that work!!!
发表于 2020-4-29 15:35:51 | 显示全部楼层
I need the same help.
GMT+8, 2025-12-30 20:48 , Processed in 0.024345 second(s), 8 queries , Gzip On, Redis On.
