查看: 4072|回复: 1
求助!!1初次使用simulink中遇到的一个问题。
发表于 2012-6-15 10:57:12 | 显示全部楼层 |阅读模式
运行之后提示:
Warning: The model 'untitled' does not have continuous states, hence Simulink is
using the solver 'VariableStepDiscrete' instead of solver 'ode45'. You can disable
this diagnostic by explicitly specifying a discrete solver in the solver tab of
the Configuration Parameters dialog, or by setting the 'Automatic solver parameter
selection' diagnostic to 'none' in the Diagnostics tab of the Configuration
Parameters dialog
请问是怎么回事,多谢了!
发表于 2012-6-20 03:31:07 | 显示全部楼层
是因你的模型是分离采样的,而Simulink的Solver是采用连续积分的。'VariableStepDiscrete'会加快模拟时间。
GMT+8, 2025-12-22 11:11 , Processed in 0.013459 second(s), 5 queries , Gzip On, Redis On.
