查看: 3891|回复: 6
[求助] ncverilog仿真SDF文件出错求助,谢谢啊
发表于 2012-6-9 22:09:09 | 显示全部楼层 |阅读模式
PR给的encounter做的SPEF文件,Primetime转换的SDF文件(用了-context verilog)
在做ATPG仿真用Ncverilog仿真时出现下面的warning:Read error for default code, skipping annotation of encounter_scan_si.sdf.X。谁知道会出现这个问题的原因啊,能提供解决方法吗,多谢
 楼主| 发表于 2012-6-10 13:43:49 | 显示全部楼层
有朋友赐教否
发表于 2012-6-10 21:32:55 | 显示全部楼层
回复 2# bluray2005
    很可能是你SDF文件格式不对。仔细看下pt里写sdf文件的命令。
 楼主| 发表于 2012-6-11 08:36:25 | 显示全部楼层
谢谢,格式肯定是对的。。。同样的tcl以前用过很多次
发表于 2012-6-12 10:28:30 | 显示全部楼层
sdf & netlist 的 topname 是否一致?
 楼主| 发表于 2012-6-12 17:13:06 | 显示全部楼层
eagle654321 发表于 2012-6-12 10:28
    是一样的
发表于 2012-6-12 17:18:16 | 显示全部楼层
The two most likely causes of this are that the compiled SDF file was corrupted or a new version of the software is expecting a different compiled SDF database format. In most cases, removing the compiled SDF file and redoing the elaboration will correct the problem and allow the annotation to proceed.
GMT+8, 2025-10-27 04:10 , Processed in 0.019496 second(s), 6 queries , Gzip On, Redis On.
