查看: 4215|回复: 1
[求助] 求解决dsp builder中signal compiler编译后的warming~
发表于 2012-6-8 14:47:38 | 显示全部楼层 |阅读模式
Critical Warning (332168): The following clock transfers have no clock uncertainty assignment. For more accurate results, apply clock uncertainty assignments or use the derive_clock_uncertainty command.
Critical Warning (332169): From Clock (Rise) to Clock (Rise) (setup and hold)
Warning (15714): Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for detailsCritical
Warning (169085): No exact pin location assignment(s) for 50 pins of 50 total pins
Warning (10036): Verilog HDL or VHDL warning at alt_dspbuilder_altimult.vhd(80): object "enadff" assigned a value but never read
Warning (10036): Verilog HDL or VHDL warning at alt_dspbuilder_altimult.vhd(85): object "aclr_i" assigned a value but never read
这些warming怎么排除呢???请详细说明。谢谢
发表于 2025-3-3 18:19:25 | 显示全部楼层
Critical Warning (169085): No exact pin location assignment(s) for 3 pins of 3 total pins         Info (169086): Pin led_light not assigned to an exact location on the device         Info (169086): Pin key_left not assigned to an exact location on the device         Info (169086): Pin key_right not assigned to an exact location on the device
GMT+8, 2025-12-14 03:34 , Processed in 0.017755 second(s), 6 queries , Gzip On, Redis On.
