楼主: longjilb
[求助] lvs出现的问题
发表于 2012-6-12 21:44:04 | 显示全部楼层
extraction report中的warning:
Extraction Errors and Warnings for cell "QB50080MWC"(这个cell是PAD)
WARNING:  Open circuit - Same name on different nets:
          (1)  at location  (0,133.23)  on layer  6 "M1"  on net id  2
          (2)  at location  (210,44.94)  on layer  36 "M2"  on net id  2
          (3)  at location  (0,44.94)  on layer  36 "M2"  on net id  2
          (4)  at location  (210,133.23)  on layer  6 "M1"  on net id  2
          (5)  at location  (210,167.49)  on layer  6 "M1"  on net id  14
          (6)  at location  (0,167.49)  on layer  6 "M1"  on net id  14
          The name was assigned to net 2 .
   Extraction Errors and Warnings for cell "AS0832_TOP_PAD"
WARNING:  Stamping conflict in SCONNECT - Multiple source nets stamp one target net.
          Use LVS REPORT OPTION S or LVS SOFTCHK statement to obtain detailed information.
这些东西如果不是在toplevel,基本可以忽略,
erc看下地方就行,
按理说pad filler是应该把所有vdd,gnd连到一起, 起连接的作用,
hhnec 不一定叫PSUB2 ,可能是别的名字,是differ each ground potential的意思,
 楼主| 发表于 2012-6-12 22:01:37 | 显示全部楼层
回复 11# icfbicfb
菜鸟还是挺迷糊的
   psub2是不是就是P型衬底啊?为什么要differ each ground potential 呢
发表于 2012-6-13 08:51:27 | 显示全部楼层
会不会是在floorplan中的Macro/pad connect时没连好导致open呢?
发表于 2014-9-17 09:54:00 | 显示全部楼层
学习学习
GMT+8, 2025-12-17 02:16 , Processed in 0.014467 second(s), 3 queries , Gzip On, Redis On.
