查看: 15089|回复: 24
[求助] smic13mmrf spectre仿真时出现错误
发表于 2012-5-31 19:41:41 | 显示全部楼层 |阅读模式
smic13mmrf spectre仿真时出现错误,整体显示如下,红色部分是其错误显示,希望各位大侠帮忙看看是什么原因造成的。
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 7.1.0.031 -- 15 Dec 2008
Copyright (C) 1989-2007 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Protected by U.S. Patents:
        5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
        6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
        6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
        6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
        7,085,700; 7,143,021.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: zhw   Host: icfb   HostID: 7F0100   PID: 13502
Memory  available: 811.3029 MB  physical: 1.6086 GB
CPU(1 of 2):  CPU 0  Pentium(R) Dual-Core CPU       T4200  @ 2.00GHz  2000.789MHz
Simulating `input.scs' on icfb at 7:21:22 PM, Thur May 31, 2012 (process id: 13502).
Command line:
    /eda/cadence/mmsim710/tools.lnx86/spectre/bin/32bit/spectre -env  \
        artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre4_11318_10 -format sst2 -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5 input.scs
spectre pid = 13502
Loading /eda/cadence/mmsim710/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /eda/cadence/mmsim710/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /eda/cadence/mmsim710/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /eda/cadence/mmsim710/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Auto-loading AHDL component.
Finished loading AHDL component in 0 s (elapsed).
Installed AHDL simulation interface.
Fatal error found by spectre during AHDL read-in.
    FATAL (VACOMP-2096): File '/export/home/zhw/smic13mmrf_1225_1P2M_200712311746/smic13mmrf_1225_1P2M_200712311746/smic13mmrf_1225/../models/spectre/res.def' does not appear to be a valid Verilog-A file. In previous releases, '.def' was a file extension typically used for SpectreHDL files but SpectreHDL is no longer supported. If this file is a SpectreHDL file, you need to replace it with an equivalent Verilog-A file.
Aggregate audit (7:21:23 PM, Thur May 31, 2012):
Time used: CPU = 922 ms, elapsed = 1 s, util. = 92.2%.
Time spent in licensing: elapsed = 701 ms, percentage of total = 70.1%.
Virtual memory used = 9 Mbytes.
spectre completes with 1 error, 0 warnings, and 0 notices.
spectre terminated prematurely due to fatal error.
发表于 2012-6-1 06:17:49 | 显示全部楼层
这好像是SMIC电阻model有两种造成的,一种是Verilog-A,还有一种好像就是电阻。一个是spectre仿真,还有一个我们用于Hsim仿真,也报过这个错。
 楼主| 发表于 2012-6-2 15:11:45 | 显示全部楼层
回复 2# amswu
   你是怎么解决的呢?是按照上面说的用Verilog-A文件代替SpectreHDL文件,具体是怎么操作的,望指教!
发表于 2012-6-2 18:08:02 | 显示全部楼层
回复 2# amswu
  下载来看看
发表于 2012-6-2 18:09:58 | 显示全部楼层
原来我09年注册的
发表于 2012-6-2 18:11:55 | 显示全部楼层
下载用了不少几分,如果CSDN是的积分可以在这里用就没有那么麻烦了
发表于 2012-6-2 18:13:39 | 显示全部楼层
发表于 2012-6-2 18:54:10 | 显示全部楼层
顶一下先
发表于 2012-6-2 18:57:10 | 显示全部楼层
顶一下先
发表于 2012-6-2 18:59:52 | 显示全部楼层
为了分数我顶
GMT+8, 2025-12-9 09:30 , Processed in 0.029049 second(s), 5 queries , Gzip On, Redis On.
