查看: 5007|回复: 2
[求助] Astro做完ECO,会出现TRI,请高手帮忙分析为什么Astro会这样做呢,谢谢帮忙
发表于 2012-5-23 16:43:05 | 显示全部楼层 |阅读模式
求助,Astro做完ECO,report timing 会出现TRI,并且TRANSITION都有100多,但仔细查看了NETLIST确实不可能是三态,贴下REPORT ,请高手帮忙分析下为什么Astro会把这些NET当做TRI呢,谢谢啦。
*   Start point : u_asic/u_ahb0_U_ahb_U_mux_r_ihmaster_data_reg_2_/CK
*   ( Rising edge-triggered flipflop clocked by clk_HCLK )
*   End point   : pad_addr[22]
*   ( Output port clocked by clk_HCLK )
*   Clock Group : clk_HCLK
*   Delay Type  : Max
*   Slack       : -805.4191  (VIOLATED)
Port/Pin             Cap   Fanout     Trans.       Incr       Arri   Reason  Master/Net
Rising edge of clock clk_HCLK                    0.0000     0.0000
Clock Source delay                               3.1619     3.1619
u_asic/uCLOCKGEN/U3603/Y
                    0.0330      2     0.1280                3.1619 r         u_asic/HCLKASTHIRNet10812 (gclock source)
u_asic/CLKBUFX16G8B10I1/A
                                      0.1280     0.0006     3.1625 r         CLKBUFX16
u_asic/CLKBUFX16G8B10I1/Y
                    0.2036      2     0.1133     0.1626     3.3251 r         u_asic/HCLK_G8B10I1ASTHNet10861
u_asic/test_point_24885__cell_12/A
                                      0.1174     0.0326     3.3577 r         CLKINVX2
u_asic/test_point_24885__cell_12/Y
                    0.0369      1     0.2639     0.1889     3.5465 f         u_asic/n254557
u_asic/test_point_24885__cell_10/A
                                      0.2641     0.0002     3.5468 f         MXI2X8
u_asic/test_point_24885__cell_10/Y
                    0.0219      2     0.1460     0.1563     3.7031 r         u_asic/n254652ASTHIRNet10514
u_asic/CLKBUFX16G10B7I1/A
                                      0.1460     0.0001     3.7032 r         CLKBUFX16
u_asic/CLKBUFX16G10B7I1/Y
                    0.2539      1     0.1225     0.1679     3.8711 r         u_asic/n254652_G10B7I1ASTHNet10458
u_asic/CLKBUFX16G10B6I1/A
                                      0.1355     0.0530     3.9241 r         CLKBUFX16
u_asic/CLKBUFX16G10B6I1/Y
                    0.3114      2     0.1589     0.1959     4.1199 r         u_asic/n254652_G10B6I1ASTHNet10271
u_asic/CLKBUFX16G10B5I2/A
                                      0.1590     0.0184     4.1383 r         CLKBUFX16
u_asic/CLKBUFX16G10B5I2/Y
                    0.1731      2     0.1020     0.1766     4.3149 r         u_asic/n254652_G10B5I2ASTHNet11001
u_asic/CLKBUFX16G10B4I4/A
                                      0.1020     0.0036     4.3186 r         CLKBUFX16
u_asic/CLKBUFX16G10B4I4/Y
                    0.2769      3     0.1440     0.1838     4.5023 r         u_asic/n254652_G10B4I4ASTHNet10255
u_asic/CLKBUFX12G10B3I11/A
                                      0.1440     0.0090     4.5113 r         CLKBUFX16
u_asic/CLKBUFX12G10B3I11/Y
                    0.1552      3     0.0978     0.1638     4.6751 r         u_asic/n254652_G10B3I11ASTHNet10969
u_asic/CLKBUFX16G10B2I36/A
                                      0.0980     0.0045     4.6796 r         CLKBUFX16
u_asic/CLKBUFX16G10B2I36/Y
                    0.2239      7     0.1226     0.1725     4.8521 r         u_asic/n254652_G10B2I36ASTHNet10677
u_asic/CLKBUFX16G10B1I233/A
                                      0.1226     0.0016     4.8537 r         CLKBUFX16
u_asic/CLKBUFX16G10B1I233/Y
                    0.0982     24     0.0727     0.1482     5.0019 r         u_asic/n254652_G10B1I233ASTHNet9929
                                      0.0727     0.0005     5.0024 r         SDFFRX1
                                      0.0727     0.0000     5.0024 r         SDFFRX1
u_asic/u_ahb0_U_ahb_U_mux_r_ihmaster_data_reg_2_/Q
                    0.0414      5     0.5644     0.6894     5.6917 r         u_asic/n93780
u_asic/U134068/C                      0.5645     0.0001     5.6918 r         NOR3BX2
u_asic/U134068/Y    0.0224      2     0.2087     0.2212     5.9130 f         u_asic/n207488
u_asic/U134068ASThfnInst1881/A
                                      0.2089     0.0002     5.9132 f         BUFX4
u_asic/U134068ASThfnInst1881/Y
                    0.1388     13     0.2760     0.3088     6.2220 f         u_asic/n207488ASThfnNet1881
u_asic/U156917/A0
                                      0.2798     0.0048     6.2268 f         AOI22X1
u_asic/U156917/Y    0.0194      1     0.5148     0.3549     6.5817 r         u_asic/n207489
u_asic/U156916/B0
                                      0.5150     0.0002     6.5819 r         OAI21X2
u_asic/U156916/Y    0.0365      1     0.2609     0.2451     6.8270 f         u_asic/n207497
u_asic/U152683/AN
                                      0.2615     0.0007     6.8277 f         NAND4BX4
u_asic/U152683/Y    0.0376      1     0.2413     0.2642     7.0919 f         u_asic/n216657
u_asic/U152683ASTttcInst7560/A
                                      0.2419     0.0007     7.0926 f         BUFX20
u_asic/U152683ASTttcInst7560/Y
                    0.2126      4     0.1066     0.2039     7.2964 f         u_asic/n216657ASTttcNet5687
u_asic/U152683ASThfnInst1869/A
                                      0.1189     0.0154     7.3118 f         BUFX2
u_asic/U152683ASThfnInst1869/Y
                    0.0790      5     0.3052     0.3189     7.6307 f         u_asic/n216657ASThfnNet1869
u_asic/U152683ASTttcInst2008/A
                                      0.3054     0.0002     7.6310 f         BUFX8
u_asic/U152683ASTttcInst2008/Y
                    0.3518     16     0.3427     0.3666     7.9976 f         u_asic/n216657ASTttcNet2008
u_asic/U136638/A1
                                      0.3596     0.0212     8.0188 f         AOI222X1
u_asic/U136638/Y    5.1467      2   117.1409    65.6257    73.6445 r    TRI  u_asic/n194814
u_asic/U158063/B                    117.1507     0.0122    73.6567 r         MXI2X1
u_asic/U158063/Y    5.1656      5    61.8003   728.7419   802.3986 f    TRI  u_asic/n216666
u_asic/U166977/A1
                                     61.8006     0.6383   803.0369 f         AOI22X1
u_asic/U166977/Y    0.0298      5     8.8050    16.6080   819.6449 r         u_asic/n216700
u_asic/U166970/A                      8.8052     0.0002   819.6451 r         XNOR2X1
u_asic/U166970/Y    0.0053      1     2.5300     1.9354   821.5806 f         u_asic/n216677
u_asic/U166969/A                      2.5300     0.0000   821.5806 f         NAND3X1
u_asic/U166969/Y    0.0041      1     0.4559     0.4804   822.0610 r         u_asic/n216678
u_asic/U156907/C0
                                      0.4559     0.0000   822.0610 r         OAI211X1
u_asic/U156907/Y    0.0150      1     0.8116     0.2506   822.3116 f         addr_per[22]
u_io_pad/U156907ASTttcInst7672/A
                                      0.8117     0.0001   822.3117 f         BUFX4
u_io_pad/U156907ASTttcInst7672/Y
                    0.0398      1     0.1161     0.3213   822.6330 f         u_io_pad/addr_per_22_ASTttcNet5758
u_io_pad/U156907ASTttcInst7671/A
                                      0.1166     0.0006   822.6336 f         BUFX12
u_io_pad/U156907ASTttcInst7671/Y
                    0.2265      1     0.1650     0.2144   822.8480 f         u_io_pad/addr_per_22_ASTttcNet5757
u_io_pad/U156907ASTttcInst19437/A
                                      0.1936     0.0357   822.8837 f         BUFX20
u_io_pad/U156907ASTttcInst19437/Y
                    0.3647      1     0.1382     0.1913   823.0750 f         u_io_pad/addr_per_22_ASTttcNet7780
u_io_pad/A22/I                        0.3748     0.1044   823.1794 f         PBU4W
u_io_pad/A22/PAD   12.1590      1     4.4712     3.3910   826.5704 f    NDT  pad_addr[22]
pad_addr[22]                          4.4712     0.0000   826.5704 f
Rising edge of clock clk_HCLK                   16.0000    16.0000
Clock Source delay                               3.1106    19.1106
Clock Network delay                              3.1408    22.2513
Clock Skew                                       0.1000    22.1513
Output delay                                     1.0000    21.1513
Required time                                              21.1513
Arrival time                                              826.5704
Slack                                                    -805.4191  (VIOLATED)
 楼主| 发表于 2012-5-23 16:54:59 | 显示全部楼层
主要是这几根NET  :
TRI  u_asic/n194814
TRI  u_asic/n216666
已经分析过NETLIST不可能出现三态,但ASTRO把它们当成了 TRI NET ,请帮帮忙啊
 楼主| 发表于 2012-5-31 11:01:52 | 显示全部楼层
现在才发现这是ASTRO的又一个BUG,ASTRO能做的事情真是有限啊
GMT+8, 2025-12-14 03:28 , Processed in 0.034414 second(s), 6 queries , Gzip On, Redis On.
