查看: 2487|回复: 3
[讨论] 请问如何解决DC时产生的这个warning
发表于 2012-5-14 14:29:17 | 显示全部楼层 |阅读模式
Warning: Net 'out_byte2_t[0]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte2_t[1]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte2_t[2]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte2_t[3]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte2_t[4]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte2_t[5]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte2_t[6]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte2_t[7]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte1_t[0]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte1_t[1]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte1_t[2]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte1_t[3]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte1_t[4]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte1_t[5]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte1_t[6]' has a single tri-state driver.  (LINT-63)
Warning: Net 'out_byte1_t[7]' has a single tri-state driver.  (LINT-63
发表于 2012-5-14 14:37:49 | 显示全部楼层
同问。
发表于 2012-5-14 15:39:24 | 显示全部楼层
确认下这个high-z输出是否是设计要求,如果是的话,不需要关心;否则,就需要修改电路
 楼主| 发表于 2012-5-14 16:15:44 | 显示全部楼层
看了一下,这些都是RAM的输出,我ram的库综合的时候也加进去了
GMT+8, 2025-12-22 14:41 , Processed in 0.014742 second(s), 6 queries , Gzip On, Redis On.
