查看: 2911|回复: 3
[讨论] HFSS VIA connection between metal6 and metal5
发表于 2012-5-11 23:31:49 | 显示全部楼层 |阅读模式
Dear all,
I have a question about the HFSS VIA usage. I hope anyone could teach me. Actually, I use HFSS to synthesize the CMOS inductor and transformer passive model. As you know that there are several substrate layer with different permittivity value. In my case, each metal embedded in each substrate layer. For example, M6 embedded in Sub6 layer and M5 embedded in Sub5 layer. There will be Via5 connected between M6 and M5. I have defined all metal, substrate and via parameters. However, I found that the Via5 does not connect with M6 and M5 after I do the simulation in HFSS (S21 is open). What do I need to set in the HFSS in order to tell it that Via5 is connect with M6 and M5?
Thanks,
 楼主| 发表于 2012-5-13 12:17:54 | 显示全部楼层
anyone could teach me?
very very thanks
发表于 2013-7-24 00:28:38 | 显示全部楼层
very very thanks
发表于 2013-9-25 20:32:27 | 显示全部楼层
貌似是网格不够,需要手动划分网格
GMT+8, 2025-12-26 03:14 , Processed in 0.016993 second(s), 6 queries , Gzip On, Redis On.
