查看: 3466|回复: 2
[招聘] NO.78-Testing Engineer(Shanghai)
发表于 2012-5-9 13:40:57 | 显示全部楼层 |阅读模式
1.Be responsible for the PCB design and testing
2.Discuss with chip designer, understanding their requirement and design the PCB board correspondingly
3.Testing the chip performance and generate test report to describe the chip test result
Job Qualification
1. B.S. in electrical engineering or equivalent is required
2. 2 or more years of PCB design experience
3. Experience of Allergo, PADS or other PCB tool is required
4. Experience of Xilinx/Altera FPGA is preferred
5. Experience of using multimeter, waveform generator, oscillograph is preferred
6. Verilog coding experience is preferred
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
发表于 2012-5-15 14:24:49 | 显示全部楼层
回复 1# KT人才
   兄弟,怎么每回给你的邮件都没有回音
 楼主| 发表于 2012-5-16 11:51:36 | 显示全部楼层
回复 2# alanhe
    是吗?不好意思,那你直接更Jilly联系吧,T:021-61023600-827   E-mail:jilly-ji@kthr.com      Mobile:15900877269
GMT+8, 2025-12-22 02:36 , Processed in 0.015943 second(s), 5 queries , Gzip On, Redis On.
