查看: 3217|回复: 0
[转贴] ATLAS and TCAD
发表于 2012-4-27 02:44:28 | 显示全部楼层 |阅读模式
ATLAS and TCAD
Device Simulation Framework
ATLAS enables device technology engineers to simulate the electrical, optical, and thermal behavior of semiconductor devices. ATLAS provides a physics-based, easy to use, modular, and extensible platform to analyze DC, AC, and time domain responses for all semiconductor based technologies in 2 and 3 dimensions.
Key Features
    * Accurately characterize physics-based devices in 2D or 3D for electrical, optical, and thermal performance without costly split-lot experiments
    * Solve yield and process variation problems for optimal combination of speed, power, density, breakdown, leakage, luminosity, or reliability
    * Fully integrated with ATHENA process simulation software, comprehensive visualization package, extensive database of examples, and simple device entry
    * Choose from the largest selection of silicon, III-V, II-VI, IV-IV, or polymer/organic technologies including CMOS, bipolar, high voltage power device, VCSEL, TFT, optoelectronic, LASER, LED, CCD, sensor, fuse, NVM, ferro-electric, SOI, Fin-FET, HEMT, and HBT
    * Connect TCAD to Tapeout with direct import of ATLAS results into UTMOST for SPICE parameter extraction
    * Parallel processing supported on multi-core and multiple processor SMP machines
    * Worldwide support
  1. http://www.multiupload.com/21WPSP1Y6D
    复制代码
  1. http://www.multiupload.com/QKF0M83PF3
    复制代码
  1. http://www.multiupload.com/3512P5VUMG
    复制代码
  1. http://www.multiupload.com/8OGAMMYS7U
    复制代码
GMT+8, 2025-12-18 23:16 , Processed in 0.014616 second(s), 5 queries , Gzip On, Redis On.
