查看: 6354|回复: 3
[求助] DC compile_ultra crash issue
发表于 2012-4-18 23:31:01 | 显示全部楼层 |阅读模式
我有一个模块,用compile命令综合没问题,把compile命令换成compile_ultra DC在开始pass 1 mapping不久以后总是崩溃,出错信息如下。
有没有高手知道为什么?我的操作系统是CentOS 6.2 64bit, 4G内存。
另外用compile_ultra不一定要读pdb或者floorplan信息吧?我用的还是老的flow, 只读了.db.
Implement Synthetic for 'interrupt'.
Error: $unined: unknown builtin function name.
Release = 'E-2010.12-SP3'  Architecture = 'amd64'  Program = 'dc_shell'
Exec = '/tools/synopsys/syn/E-2010.12-SP3/amd64/syn/bin/common_shell_exec'
'125835751 125836022 125836395 245094216864 65316400 65088128 64951158 64956554 64959029 64913659 66472215 26905912 26944163 26952676 26954852 26955682 26956316 26835789 26839572 26888687 26889651 31531529 31550196 31555764 26892375 26871635 26882347 22967308 22970962 22057324 125046909 125190358 127522047 127527714 127677865 127696902 127531812 127576246 127527714 127528559 125102626 125157778 125190358 127522047 127527714 127528559 125181928 125187769 18812607 18832176 18834253 18835738 4375666 4361897 245081697501'
Error: O1[28:0]=I1-$unined(1'b11);;O2=I2==$unsigned(O1)O33=I3==$unsigeed(1)): Syntax error in SOP expression.
Error: Unexpected termination of job J14
Error: *** Generation of expr O1[28:0]=I1-$unined(1'b11);;O2=I2==$unsigned(O1)Odcfarm: detected bad exit for job 13400, name J14 -- terminating all child jobs now...
dcfarm: destroying parent process due to child fatal
'125835751 125837416 125960761 31556309 26892375 26871635 26882347 22967308 22970962 22057324 125046909 125190358 127522047 127527714 127677865 127696902 127531812 127576246 127527714 127528559 125102626 125157778 125190358 127522047 127527714 127528559 125181928 125187769 18812607 18832176 18834253 18835738 4375666 4361897 245081697501'
 楼主| 发表于 2012-4-22 18:01:25 | 显示全部楼层
看起来我的Linux操作系统版本太高了,Synopsys目前才支持到redhat 5.5,G-Foundation什么时候才release呢?否则我只有降级我的系统了。
发表于 2014-1-9 21:43:56 | 显示全部楼层
Cant solve DC Ultra license issue
发表于 2021-9-1 11:51:57 | 显示全部楼层
楼主,解决了吗
GMT+8, 2025-10-22 05:24 , Processed in 0.016829 second(s), 7 queries , Gzip On, Redis On.
