查看: 21370|回复: 39
ic610 lisence 及变量设置问题 在线等!
发表于 2012-3-15 11:25:19 | 显示全部楼层 |阅读模式
按照网络上的步骤安装好了之后。
打开终端输入lmli回车
出现the lisence server manager (lmgrd) running as root:this is a potential security problem and is not recommended
这是什么意思?????软件能够打开。但是不能新建cell?
我在想是不是我在安装的时候直接在root账号下装cadence的原因?????
我应该先用root账户新建一个使用者的的账号。在使用者的账号里安装软件????
这么理解对么???
另外软件提供商所给的lisence里有固定的server name 和host id值。
通过代码我已经将mac地址改为所需的值。请问这个server name怎么在linux上修改?代码是什么?
另外server name和host name是一个东西么?应该不是吧?????我会修改host name。。。。
问题较多。。。。。还请高手火速回答。在线等
附上终端显示的错误:
[root@localhost ~]# lmli
10:29:30 (lmgrd) -----------------------------------------------
10:29:30 (lmgrd)   Please Note:
10:29:30 (lmgrd)
10:29:30 (lmgrd)   This log is intended for debug purposes only.
10:29:30 (lmgrd)   In order to capture accurate license
10:29:30 (lmgrd)   usage data into an organized repository,
10:29:30 (lmgrd)   please enable report logging. Use Macrovision's
10:29:30 (lmgrd)   software license administration  solution,
10:29:30 (lmgrd)   FLEXnet Manager, to  readily gain visibility
10:29:30 (lmgrd)   into license usage data and to create
10:29:30 (lmgrd)   insightful reports on critical information like
10:29:30 (lmgrd)   license availability and usage. FLEXnet Manager
10:29:30 (lmgrd)   can be fully automated to run these reports on
10:29:30 (lmgrd)   schedule and can be used to track license
10:29:30 (lmgrd)   servers and usage across a heterogeneous
10:29:30 (lmgrd)   network of servers including Windows NT, Linux
10:29:30 (lmgrd)   and UNIX. Contact Macrovision at
10:29:30 (lmgrd)   www.macrovision.com for more details on how to
10:29:30 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
10:29:30 (lmgrd)   for your enterprise.
10:29:30 (lmgrd)
10:29:30 (lmgrd)
10:29:30 (lmgrd)
10:29:30 (lmgrd) The license server manager (lmgrd) running as root:
10:29:30 (lmgrd)        This is a potential security problem
10:29:30 (lmgrd)        and is not recommended.
/home/yqli/eda/ic610/share/license/license.dat: line 1: SERVER: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 2: DAEMON: command not found
: command not found0/share/license/license.dat: line 4: USE_SERVER
/home/yqli/eda/ic610/share/license/license.dat: line 5: FEATURE: command not found
: command not found0/share/license/license.dat: line 6:
/home/yqli/eda/ic610/share/license/license.dat: line 7: V7.1_LK=FDAE0FEF1E91C8FD: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 11: FEATURE: command not found
: command not found0/share/license/license.dat: line 12:
/home/yqli/eda/ic610/share/license/license.dat: line 13: V7.1_LK=ADEE5FCF9E773E9: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 17: FEATURE: command not found
: command not found0/share/license/license.dat: line 18:
/home/yqli/eda/ic610/share/license/license.dat: line 19: V7.1_LK=8D9E2FDFC59E806: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 23: FEATURE: command not found
: command not found0/share/license/license.dat: line 24:
/home/yqli/eda/ic610/share/license/license.dat: line 25: V7.1_LK=9D3E7F1FC7F4B9E: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 29: FEATURE: command not found
: command not found0/share/license/license.dat: line 30:
/home/yqli/eda/ic610/share/license/license.dat: line 31: V7.1_LK=BD3E7FFF8D12E77: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 35: FEATURE: command not found
: command not found0/share/license/license.dat: line 36:
/home/yqli/eda/ic610/share/license/license.dat: line 37: V7.1_LK=7DAE5F2F96436DA: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 41: FEATURE: command not found
: command not found0/share/license/license.dat: line 42:
/home/yqli/eda/ic610/share/license/license.dat: line 43: V7.1_LK=2DAE1F5FD3AAAE7: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 47: FEATURE: command not found
: command not found0/share/license/license.dat: line 48:
/home/yqli/eda/ic610/share/license/license.dat: line 49: V7.1_LK=4D8E8F5FA54F1F7: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 53: FEATURE: command not found
: command not found0/share/license/license.dat: line 54:
/home/yqli/eda/ic610/share/license/license.dat: line 55: V7.1_LK=1D0E1F8F0824001: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 59: FEATURE: command not found
: command not found0/share/license/license.dat: line 60:
/home/yqli/eda/ic610/share/license/license.dat: line 61: V7.1_LK=CD0E7FEFB357A4F: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 65: FEATURE: command not found
: command not found0/share/license/license.dat: line 66:
/home/yqli/eda/ic610/share/license/license.dat: line 67: V7.1_LK=CDFE8F6F83FEEFB: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 71: FEATURE: command not found
: command not found0/share/license/license.dat: line 72:
/home/yqli/eda/ic610/share/license/license.dat: line 73: V7.1_LK=5D2E2F3FBE8AC6E: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 77: FEATURE: command not found
: command not found0/share/license/license.dat: line 78:
/home/yqli/eda/ic610/share/license/license.dat: line 79: V7.1_LK=CD7E4F2FEFB2F9A: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 83: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 84: ADDE3F0F5A7F0F35AB0F: command not found
: command not found0/share/license/license.dat: line 85:
/home/yqli/eda/ic610/share/license/license.dat: line 86: V7.1_LK=BD3E2F9F6184032: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 90: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 91: 6DDE2F5FEAA68E20AD25: command not found
: command not found0/share/license/license.dat: line 92:
/home/yqli/eda/ic610/share/license/license.dat: line 93: V7.1_LK=7DFE2FCF4089952: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 97: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 98: AD5E7F6FFCAB3E3A1ACA: command not found
: command not found0/share/license/license.dat: line 99:
/home/yqli/eda/ic610/share/license/license.dat: line 100: V7.1_LK=CD7EFF0F0D93BA: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 104: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 105: DD3EAFFF352248ADD967: command not found
: command not found0/share/license/license.dat: line 106:
/home/yqli/eda/ic610/share/license/license.dat: line 107: V7.1_LK=CD5EBF8F3B7371: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 111: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 112: DDCE7F9F04A82F9BD4F9: command not found
: command not found0/share/license/license.dat: line 113:
/home/yqli/eda/ic610/share/license/license.dat: line 114: V7.1_LK=FD4E9FFF02D032: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 118: FEATURE: command not found
: command not found0/share/license/license.dat: line 119:
/home/yqli/eda/ic610/share/license/license.dat: line 120: V7.1_LK=EDDEBF6F55A352: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 124: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 125: ADBE1F4FAE69E5B24801: command not found
: command not found0/share/license/license.dat: line 126:
/home/yqli/eda/ic610/share/license/license.dat: line 127: V7.1_LK=3DBE8FCF21D9F2: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 131: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 132: 3D5E2F8FD877EBF616D7: command not found
: command not found0/share/license/license.dat: line 133:
/home/yqli/eda/ic610/share/license/license.dat: line 134: V7.1_LK=3D5E2F0FDB77D8: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 138: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 139: AD2E3F9F47DD1148C2DA: command not found
: command not found0/share/license/license.dat: line 140:
/home/yqli/eda/ic610/share/license/license.dat: line 141: V7.1_LK=AD6E3FDFF6D92A: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 145: FEATURE: command not found
: command not found0/share/license/license.dat: line 146:
/home/yqli/eda/ic610/share/license/license.dat: line 147: V7.1_LK=3DFE6FCF9C6D9C: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 151: FEATURE: command not found
: command not found0/share/license/license.dat: line 152:
/home/yqli/eda/ic610/share/license/license.dat: line 153: V7.1_LK=ADDE2F4FC7528B: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 157: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 158: 6D3E9F8F21C550C693CA: command not found
: command not found0/share/license/license.dat: line 159:
/home/yqli/eda/ic610/share/license/license.dat: line 160: V7.1_LK=FD0EFF4FF518C4: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 164: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 165: 3DAE6F9F8C8523255A2E: command not found
: command not found0/share/license/license.dat: line 166:
/home/yqli/eda/ic610/share/license/license.dat: line 167: V7.1_LK=4DAE6F1F837D28: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 171: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 172: BD9E9FAF848F8BDEBE21: command not found
: command not found0/share/license/license.dat: line 173:
/home/yqli/eda/ic610/share/license/license.dat: line 174: V7.1_LK=9DEE7F4F906A8E: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 178: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 179: AD1E9F2F91B959DCBF2F: command not found
: command not found0/share/license/license.dat: line 180:
/home/yqli/eda/ic610/share/license/license.dat: line 181: V7.1_LK=8DBE7FBFAFDE12: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 185: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 186: BDDE1FDF0A7BBBDD2465: command not found
: command not found0/share/license/license.dat: line 187:
/home/yqli/eda/ic610/share/license/license.dat: line 188: V7.1_LK=7DDEFFFF8C3BBA: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 192: FEATURE: command not found
: command not found0/share/license/license.dat: line 193:
/home/yqli/eda/ic610/share/license/license.dat: line 194: V7.1_LK=6D6EEF7F0004A7: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 198: FEATURE: command not found
: command not found0/share/license/license.dat: line 199:
/home/yqli/eda/ic610/share/license/license.dat: line 200: V7.1_LK=CDBE8FCFB1D0E7: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 204: FEATURE: command not found
: command not found0/share/license/license.dat: line 205:
/home/yqli/eda/ic610/share/license/license.dat: line 206: V7.1_LK=0D2E7FAF919057: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 210: FEATURE: command not found
: command not found0/share/license/license.dat: line 211:
/home/yqli/eda/ic610/share/license/license.dat: line 212: V7.1_LK=0DEEEF2F9D1447: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 216: FEATURE: command not found
: command not found0/share/license/license.dat: line 217:
/home/yqli/eda/ic610/share/license/license.dat: line 218: V7.1_LK=4D4EDFAF01547C: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 222: FEATURE: command not found
: command not found0/share/license/license.dat: line 223:
/home/yqli/eda/ic610/share/license/license.dat: line 224: V7.1_LK=6D2EFF3F2894E8: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 228: FEATURE: command not found
: command not found0/share/license/license.dat: line 229:
/home/yqli/eda/ic610/share/license/license.dat: line 230: V7.1_LK=5D2E6F0F87F30F: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 234: FEATURE: command not found
: command not found0/share/license/license.dat: line 235:
/home/yqli/eda/ic610/share/license/license.dat: line 236: V7.1_LK=BDCEDF8F67E9FB: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 240: FEATURE: command not found
: command not found0/share/license/license.dat: line 241:
/home/yqli/eda/ic610/share/license/license.dat: line 242: V7.1_LK=1DEE9F4FB52307: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 246: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 247: 1DAEBF8FEECCFA966EC0: command not found
: command not found0/share/license/license.dat: line 248:
/home/yqli/eda/ic610/share/license/license.dat: line 249: V7.1_LK=1D8EDF2FF3D42E: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 253: FEATURE: command not found
: command not found0/share/license/license.dat: line 254:
/home/yqli/eda/ic610/share/license/license.dat: line 255: V7.1_LK=DD3E4FCF87D9B0: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 259: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 260: 5D1E6FDFAA9690CA0D8D: command not found
: command not found0/share/license/license.dat: line 261:
/home/yqli/eda/ic610/share/license/license.dat: line 262: V7.1_LK=5D2E5FBF46B583: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 266: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 267: FD5E3FFFF1D4E54480DA: command not found
: command not found0/share/license/license.dat: line 268:
/home/yqli/eda/ic610/share/license/license.dat: line 269: V7.1_LK=CD7E0F0F1C71E9: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 273: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 274: 7DEE0F5F5555F3D29EB4: command not found
: command not found0/share/license/license.dat: line 275:
/home/yqli/eda/ic610/share/license/license.dat: line 276: V7.1_LK=7D4E1F2F2F4EFC: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 280: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 281: 9D0E3F9FB6B39CC4BD9B: command not found
: command not found0/share/license/license.dat: line 282:
/home/yqli/eda/ic610/share/license/license.dat: line 283: V7.1_LK=8D2EAF2FBC38FD: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 287: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 288: 6D6E2F1FE503DC8A48B3: command not found
: command not found0/share/license/license.dat: line 289:
/home/yqli/eda/ic610/share/license/license.dat: line 290: V7.1_LK=6D0E1FFFE207D4: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 294: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 295: FD5E6F1F135F635C366F: command not found
: command not found0/share/license/license.dat: line 296:
/home/yqli/eda/ic610/share/license/license.dat: line 297: V7.1_LK=FD4E5FEF115F61: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 301: FEATURE: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 302: 7DAE6F7F5D07AA1DAF6F: command not found
: command not found0/share/license/license.dat: line 303:
/home/yqli/eda/ic610/share/license/license.dat: line 304: V7.1_LK=8DCE4F8F3084F2: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 308: FEATURE: command not found
: command not found0/share/license/license.dat: line 309:
/home/yqli/eda/ic610/share/license/license.dat: line 310: V7.1_LK=8DAEEF6FBDBF49: command not found
/home/yqli/eda/ic610/share/license/license.dat: line 314: FEATURE: command not found
: command not found0/share/license/license.dat: line 315:
/home/yqli/eda/ic610/share/license/license.dat: line 316: V7.1_LK=CD7E5F7FE0DAB4: command not found
[root@localhost ~]# 10:29:45 (lmgrd) The TCP port number in the license, 5280, is already in use.
10:29:45 (lmgrd) Possible causes:
10:29:45 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
10:29:45 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
10:29:45 (lmgrd)    3) Another process is using this port number (unlikely).
10:29:45 (lmgrd) Solutions:
10:29:45 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
10:29:45 (lmgrd)       license are not running.
10:29:45 (lmgrd)    2) You may have to wait for the OS to clear this port.
10:29:45 (lmgrd) Retrying for about 5 more minutes
10:30:03 (lmgrd) Still trying...
10:30:21 (lmgrd) Still trying...
10:30:39 (lmgrd) Still trying...
10:30:57 (lmgrd) Still trying...
10:31:15 (lmgrd) Still trying...
10:31:33 (lmgrd) Still trying...
10:31:51 (lmgrd) Still trying...
10:32:09 (lmgrd) Still trying...
10:32:27 (lmgrd) Still trying...
10:32:45 (lmgrd) Still trying...
10:33:03 (lmgrd) Still trying...
10:33:18 (lmgrd) Failed to open the TCP port number in the license.
 楼主| 发表于 2012-3-15 13:32:30 | 显示全部楼层
没人知道么????很着急额
发表于 2012-3-15 14:43:10 | 显示全部楼层
应该是你在root下装软件的原因。
 楼主| 发表于 2012-3-15 14:59:38 | 显示全部楼层
回复 3# tomwinner
    您好。那我该怎么办?全部删除?然后新开一个账户。然后再重新安装啊????有没有比较简洁的方法了????
发表于 2012-3-15 15:11:30 | 显示全部楼层
建一个普通用户安装。linux下安装软件不能在root下是基本条件啊。
 楼主| 发表于 2012-3-15 15:17:29 | 显示全部楼层
回复 5# tomwinner
    好吧。本人刚接触linux。还不是很懂。另外我想问。5280端口被占用后该怎么办?????
发表于 2012-3-15 15:27:52 | 显示全部楼层
我也刚接触linux不到1个月。。。幸好找了个前辈装了一次ic5141,之后一些软件基本都自己安装设置好了。一些具体问题我也无法解释的。。。
 楼主| 发表于 2012-3-15 15:36:32 | 显示全部楼层
回复 7# tomwinner
    不知道您能否帮我向您的这位前辈引荐一下。。我装这个软件快崩溃了额。。谢谢你的回答。
如果不方便引荐,也没有关系。只是希望有个人带一下。能快点上手。
发表于 2012-3-15 15:42:30 | 显示全部楼层
回复 8# 苦寻爱
没办法的,我自己最近都有很多问题,他很忙都没时间帮我。论坛里也有很多牛人,去对应的区域发帖问问,会有人回答的。多看些基本资料吧。
 楼主| 发表于 2012-3-15 16:15:28 | 显示全部楼层
回复 9# tomwinner
    好的。谢谢您~@!
GMT+8, 2025-12-23 09:42 , Processed in 0.020954 second(s), 5 queries , Gzip On, Redis On.
