查看: 17105|回复: 16
[求助] 新手求助,encounter单元放置问题(已解决)
发表于 2012-2-28 10:39:44 | 显示全部楼层 |阅读模式
求助各位大大,从dc综合后输出的sdc文件在encounter里面放置标准单元时出现了这个问题,请问下怎么解决呢?另外encounter是否有像dc一样的error说明文件?
*** Starting placeDesign default flow ***
CTE reading timing constraint file '/usr/synopsys/10.9.1/linux/bin/mux.sdc' ...
ERROR (CTE-2): scripts aborted prematurely, turning off message_verbosity
ERROR (CTE-27): read_dc_script aborted prematurely extra characters after close-quote
    while executing
"(SDFVERSION "OVI 2.1")
    (file "/usr/synopsys/10.9.1/linux/bin/mux.sdc" line 2)
    invoked from within
"__source /usr/synopsys/10.9.1/linux/bin/mux.sdc"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 __source /usr/synopsys/10.9.1/linux/bin/mux.sdc"
    ("eval" body line 1)
    invoked from within
"eval "uplevel #0 $syn2ambit::source_cmd $::syn2ambit::tcl_file_G""
WARNING (CTE-25): Line: 1 of File /usr/synopsys/10.9.1/linux/bin/mux.sdc : Skipped unsupported command: (DELAYFILE
**ERROR: (SOCCTE-10):   read_dc_script /usr/synopsys/10.9.1/linux/bin/mux.sdc failed
*** Start deleteBufferTree ***
Info: Detect buffers to remove automatically.
 楼主| 发表于 2012-2-28 10:40:32 | 显示全部楼层
我的sdc文件开头是这些
(DELAYFILE
(DESIGN "mux")
(DATE "Tue Feb 28 09:27:46 2012")
(VENDOR "typical")
(PROGRAM "Synopsys Design Compiler cmos")
(VERSION "C-2009.06-SP4")
(DIVIDER /)
(VOLTAGE 1.80:1.80:1.80)
(PROCESS "typical")
(TEMPERATURE 25.00:25.00:25.00)
(TIMESCALE 1ns)
(CELL
  (CELLTYPE "mux")
  (INSTANCE)
  (DELAY
    (ABSOLUTE
    (INTERCONNECT mult_14/U110/Y dataout_reg_0_/D
发表于 2012-2-28 11:38:15 | 显示全部楼层
这哪是sdc啊!!!
 楼主| 发表于 2012-2-28 12:18:04 | 显示全部楼层
回复 3# 陈涛
版主大大,那这是什么。。。dc出来的就是这个啊。。
发表于 2012-2-28 13:37:07 | 显示全部楼层
那叫sdf
 楼主| 发表于 2012-2-28 14:49:33 | 显示全部楼层
回复 5# 陈涛
   恩,我弄错了。改过之后,貌似还是不行,出现这些。。请问哪里还有问题呢?*** Starting placeDesign default flow ***
Analyzing netlist ...
Updating netlist
*summary: 0 instances (buffers/inverters) removed
*** Finish deleteBufferTree (0:00:00.0) ***
*** Starting "NanoPlace(TM) placement v0.845 (mem=234.5M)" ...
*** Build Buffered Sizing Timing Model
(cpu=0:00:03.0 mem=234.5M) ***
*** Build Virtual Sizing Timing Model
(cpu=0:00:03.4 mem=234.5M) ***
Options: timingDriven ignoreScan ignoreSpare pinGuide gpeffort=medium
**WARN: (SOCDB-2082):   Scan chains were not defined, -ignoreScan option will be ignored.
Please first define the scan chains before using this option.
#std cell=205 #block=0 (0 floating + 0 preplaced) #ioInst=0 #net=265 #term=737 #term/net=2.78, #fixedIo=0, #floatIo=0, #fixedPin=0, #floatPin=34
stdCell: 205 single + 0 double + 0 multi
Total standard cell length = 1.1266 (mm), area = 0.0057 (mm^2)
Average module density = 0.707.
Density for the design = 0.707.
       = stdcell_area 1707 (5678 um^2) / alloc_area 2416 (8037 um^2).
Pin Density = 0.432.
            = total # of pins 737 / total Instance area 1707.
Iteration  1: Total net bbox = 5.226e+03 (2.98e+03 2.24e+03)
              Est.  stn bbox = 5.226e+03 (2.98e+03 2.24e+03)
              cpu = 0:00:00.0 real = 0:00:00.0 mem = 234.6M
Iteration  2: Total net bbox = 5.226e+03 (2.98e+03 2.24e+03)
Iteration  3: Total net bbox = 4.463e+03 (2.53e+03 1.93e+03)
              Est.  stn bbox = 4.463e+03 (2.53e+03 1.93e+03)
Iteration  4: Total net bbox = 5.368e+03 (3.00e+03 2.37e+03)
              Est.  stn bbox = 5.368e+03 (3.00e+03 2.37e+03)
Iteration  5: Total net bbox = 5.512e+03 (3.08e+03 2.43e+03)
              Est.  stn bbox = 5.512e+03 (3.08e+03 2.43e+03)
Iteration  6: Total net bbox = 6.912e+03 (4.54e+03 2.37e+03)
              Est.  stn bbox = 7.588e+03 (4.96e+03 2.63e+03)
              cpu = 0:00:00.1 real = 0:00:00.0 mem = 234.6M
*** cost = 6.912e+03 (4.54e+03 2.37e+03) (cpu for global=0:00:00.1) real=0:00:00.0***
Core Placement runtime cpu: 0:00:00.1 real: 0:00:00.0
Starting refinePlace ...
Placement tweakage begins.
wire length = 7.410e+03 = 4.811e+03 H + 2.599e+03 V
wire length = 6.033e+03 = 3.416e+03 H + 2.617e+03 V
Placement tweakage ends.
Statistics of distance of Instance movement in detailed placement:
  maximum (X+Y) =        24.60 um
  inst (mult_14/U48) with max move: (62.04, 70.56) -> (47.52, 80.64)
  mean    (X+Y) =         7.26 um
Total instances flipped : 3
Total instances moved : 146
*** cpu=0:00:00.0   mem=234.6M  mem(used)=0.0M***
Total net length = 6.123e+03 (3.416e+03 2.707e+03) (ext = 2.029e+03)
*** End of Placement (cpu=0:00:03.6, real=0:00:03.0, mem=234.6M) ***
default core: bins with density >  0.75 =   25 % ( 1 / 4 )
*** Free Virtual Timing Model ...(mem=234.5M)
Starting IO pin assignment...
Completed IO pin assignment.
**WARN: (SOCSP-9025):   No scan chain specified/traced.
*** Finishing placeDesign default flow ***
**placeDesign ... cpu = 0: 0: 4, real = 0: 0: 4, mem = 234.5M **
 楼主| 发表于 2012-2-28 14:51:25 | 显示全部楼层
回复 6# zhq415758192
   恩,是我的错误。多谢指点~
发表于 2012-2-28 14:54:31 | 显示全部楼层
哪里不行?
 楼主| 发表于 2012-2-28 15:00:09 | 显示全部楼层
回复 9# 陈涛
   标准单元好像还没有加进去。。
发表于 2012-2-28 16:05:47 | 显示全部楼层
用GUI确认标准单元是否加进去
GMT+8, 2025-12-28 16:24 , Processed in 0.024968 second(s), 4 queries , Gzip On, Redis On.
