楼主: tomwinner
[求助] 新手求助,encounter单元放置问题(已解决)
发表于 2012-2-28 16:05:47 | 显示全部楼层
用GUI确认标准单元是否加进去
 楼主| 发表于 2012-2-28 16:24:37 | 显示全部楼层
回复 11# 陈涛
   没有,GUI看不到变化。。
发表于 2012-2-28 16:30:17 | 显示全部楼层
/usr/synopsys/10.9.1/linux/bin/mux.sdc
这个文件路径有意思
你都有下面的信息了,还说没有放进去?
Statistics of distance of Instance movement in detailed placement:
  maximum (X+Y) =        24.60 um
  inst (mult_14/U48) with max move: (62.04, 70.56) -> (47.52, 80.64)
  mean    (X+Y) =         7.26 um
Total instances flipped : 3
Total instances moved : 146
发表于 2012-2-28 16:58:49 | 显示全部楼层
从他一开始的问题就知道,在初学者身上,什么都有可能发生,估计他是GUI的view没有选对
 楼主| 发表于 2012-2-28 17:01:30 | 显示全部楼层
回复 13# damonzhao
  抱歉啊 [img]file:///C:\Users\Administrator\AppData\Roaming\Tencent\Users\260523658\QQ\WinTemp\RichOle\X2}[TR8G(S97FI`3FLFB{G6.jpg[/img]我才学习使用encounter的。。。按照流程范例做,确实到了这部就走不下去了。。。
 楼主| 发表于 2012-2-28 17:05:41 | 显示全部楼层
回复 14# 陈涛
  果然是,谢谢版主!!
发表于 2014-12-5 10:38:42 | 显示全部楼层
我的也加不进去,
total 2479 rectangles on layer m1 in cell CMPE4, which exceed the limit 1000. Stop merging on this layer.
**info: total 1136 rectangles on layer m1 in cell SDFPNSNRQQB1, which exceed the limit 1000. Stop merging on this layer.
**info: total 1200 rectangles on layer m1 in cell SDFPNSNRQQB2, which exceed the limit 1000. Stop merging on this layer.
**info: total 1426 rectangles on layer m1 in cell SDFPSBNRQ1, which exceed the limit 1000. Stop merging on this layer.
**info: total 1406 rectangles on layer m1 in cell SDFPSBNRQ2, which exceed the limit 1000. Stop merging on this layer.
**info: total 1433 rectangles on layer m1 in cell SDFPSBNRQQB1, which exceed the limit 1000. Stop merging on this layer.
**info: total 1297 rectangles on layer m1 in cell SDFPSBNRQQB2, which exceed the limit 1000. Stop merging on this layer.
**info: total 1232 rectangles on layer m1 in cell SDFSBNRQ1, which exceed the limit 1000. Stop merging on this layer.
**info: total 1251 rectangles on layer m1 in cell SDFSBNRQ2, which exceed the limit 1000. Stop merging on this layer.
**info: total 1115 rectangles on layer m1 in cell SDFSBNRQQB1, which exceed the limit 1000. Stop merging on this layer.
**info: total 1521 rectangles on layer m1 in cell SDFSBNRQQB2, which exceed the limit 1000. Stop merging on this layer.
default core: bins with density >  0.75 = 16.7 % ( 1 / 6 )
*** Free Virtual Timing Model ...(mem=324.4M)
这是什么问题?
GMT+8, 2025-12-23 04:03 , Processed in 0.019114 second(s), 5 queries , Gzip On, Redis On.
