查看: 2793|回复: 4
[求助] 4位计数器找错,谢谢!
发表于 2012-2-6 10:57:40 | 显示全部楼层 |阅读模式
本菜鸟刚开始学习VHDL,下面这段程序是按照书上输入到电脑中的,用quartusII 11.0进行仿真,出现了4个错误,应该是少了个标点之类的错误,但我对着书几遍了都没发现哪有错,希望有高手指点,谢谢!
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity cnt4 is
port
( rst:in std_logic;
d:in std_logic_vector(3 downto 0);
load:in std_logic;
clk,ce:in std_logic;
q: out std_logic_vector(3 downto 0);
cout: out std_logic
end entity cnt4;
architecture syn of cnt4 is
signal count:std_logic_vector(3 downto 0);
begin
cntproc:process(clk,rst) begin
if rst= '1' then
  count<=(others=>'0');
elseif rising_edge(clk)  then
  if ce= '1' then
   if load= '1' then
   count<=d;  else
   count<=count+1;
   end if;
  end if;
end if;
end process;
coutproc:process(clk,rst) begin
if rst='1' then
cout<='0';
if count="1111" then
cout<='1';  else
cout<='0';
end if;
end if;
end process;
q<=count;
end syn;
错误如下:
Error (10500): VHDL syntax error at cnt4.vhd(20) near text "rising_edge";  expecting "(", or "'", or "."
Error (10500): VHDL syntax error at cnt4.vhd(20) near text "then";  expecting "(", or "'", or "."
Error (10500): VHDL syntax error at cnt4.vhd(32) near text "rising_edge";  expecting "(", or "'", or "."
Error (10500): VHDL syntax error at cnt4.vhd(32) near text "then";  expecting "(", or "'", or "."
Error: Quartus II 32-bit Create Symbol File was unsuccessful. 4 errors, 0 warnings
Error: Peak virtual memory: 283 megabytes
Error: Processing ended: Mon Feb 06 10:47:57 2012
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:02
对着这段程序一个早上,都找不着错在哪里,还希望有高手帮忙一下!
发表于 2012-2-6 14:35:17 | 显示全部楼层
现在用vhdl的人越来越才了,还是换成verilog吧
发表于 2012-2-6 15:27:49 | 显示全部楼层
为什么呢,没有人用vhdl了吗
发表于 2012-2-6 15:55:00 | 显示全部楼层
好象是ELSEIF错了吧。 可以写成ELSIF或者ELSE IF试试看。
 楼主| 发表于 2012-2-6 16:12:32 | 显示全部楼层
回复 4# wkx820313
    谢谢!果然改成elsif就没有错误了!
GMT+8, 2025-12-23 01:13 , Processed in 0.021258 second(s), 8 queries , Gzip On, Redis On.
