查看: 3083|回复: 5
[资料] Calculating Gain for Audio Amplifiers (TI)
发表于 2011-12-19 21:59:22 | 显示全部楼层 |阅读模式
ABSTRACT
  This application report explains the different types of audio power
amplifier configurations, such as the single-ended (SE), the bridge-tied
load (BTL) and the fully differential audio amplifier. Each configuration is
illustrated with a block diagram, gain equations, and an example using
realistic scenarios to illustrate to engineers how to calculate the gain of
their audio amplifier.
Contents :
1 Introduction ...........................................................................2
  1.1 Power Into a Speaker..........................................................2
  1.2 Speaker Impedance ............................................................2
  1.3 Gain Setting for the Audio Power Amplifier ............................2
2 The Single-Ended (SE) Audio Power Amplifier .............................3
  2.1 Design ..............................................................................3
  2.2 Equation ...........................................................................3
  2.3 SE Example........................................................................4
3 The Bridge-Tied Load (BTL) Audio Power Amplifier ......................6
  3.1 Design ..............................................................................6
  3.2 Equation ...........................................................................6
  3.3 BTL Example.......................................................................7
4 The Fully Differential Audio Power Amplifier .................................9
  4.1 Design ...............................................................................9
  4.2 Equation ............................................................................9
  4.3 Fully Differential Example.....................................................10
5 Conclusion..............................................................................13
Calculating Gain for Audio Amplifiers.pdf
238.59 KB, 下载次数: 95 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2012-1-8 03:53:43 | 显示全部楼层
Thanks!
发表于 2012-10-10 10:49:22 | 显示全部楼层
好东西。
发表于 2016-5-23 15:32:50 | 显示全部楼层
THANK YOU
发表于 2017-10-29 21:33:52 | 显示全部楼层
回复 1# tingwu7
a good paper.
发表于 2017-10-30 03:14:22 | 显示全部楼层
非常感謝~~~~
GMT+8, 2025-11-16 16:34 , Processed in 1.114698 second(s), 6 queries , Gzip On, Redis On.
