查看: 2316|回复: 1
[原创] I2C VHDL 语言实现
发表于 2011-12-19 09:46:54 | 显示全部楼层 |阅读模式
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.std_logic_arith.all ;
use ieee.std_logic_unsigned.all ;
entity I2C_Control is
              port (
      CLKI      :IN     Std_logic ;
      RST    :IN     Std_logic ;
      Slave_add  :in  std_logic_vector(3 downto 0);
      addr   :in  std_logic_vector(7 downto 0);
      wr_rd   :IN     Std_logic ;
      DAT1   :in  std_logic_vector(7 downto 0);
      Delay_Time  :in  integer range 0 to 255;
      A    :buffer std_logic_vector(2 downto 0);
      WP    :buffer std_logic;
      SCL    :buffer std_logic;
      SDA    :buffer std_logic
end I2C_Control ;
architecture Arch of I2C_Control is
  type state1 is (Idle,Idle1, I1,I2,I3,I4,I5,I6,I7,I8,I9,I10,Iok);
  signal current_state,next_state : state1;
  signal I2C_Sent  :std_logic_vector(26 downto 0);
begin
I2C_Sent <= Slave_add & A & wr_rd &'0'& addr &'0'& DAT1&'0' ;
process(clki,RST)
begin
  if RST = '1' then
   current_state <= Idle;
  elsif clki'event and clki = '0' then
   current_state <= next_state;
  end if;
end process;
process(clki)
variable i            :integer range 0 to 63;
variable cnt          :integer range 0 to 1023;
begin
  if clki'event and clki = '1' then
      A<="111";
   case current_state is
    when Idle =>
        SCL <= '1'; SDA <= '1';
        WP <= '1';
        next_state <= Idle1;
    when Idle1 =>
        WP <= '0';
        next_state <= I1;
    when I1   =>
        SDA <= '0';
        next_state <= I2;
    when I2   =>
        SCL <= '0';
        i :=26;
        next_state <= I3;
    when I3   =>
                    SCL <= '0';
        SDA <= I2C_Sent(i);
        next_state <= I4;
    when I4   =>
        SCL <= '1';
        next_state <= I5;
    when I5   =>
        if i= 0 then
         next_state <= I6;
        else
         i := i-1;
         next_state <= I3;
        end if;
    when I6   =>
        SCL <= '0';
        next_state <= I7;
          when I7   =>
          SCL<= '1';
        next_state <= I8;
    when I8   =>
          SDA <= '1';
        next_state <= I9;
    when I9   =>
        WP<= '1';  --1
        next_state <= I10;
    WHEN I10 =>
        if cnt = Delay_Time then
         cnt := 0;
         next_state <= Idle;
        else
         cnt := cnt +1;
        end if;
    when Iok  =>
        SCL <='1';
        SDA <= '1';
        next_state <= Iok;
    when others =>
        next_state <= Iok;
   end case;
  end if;
end process;
end Arch;
发表于 2011-12-19 10:54:35 | 显示全部楼层
很好!
很精彩!
GMT+8, 2025-12-23 22:32 , Processed in 0.018221 second(s), 7 queries , Gzip On, Redis On.
