楼主: power0650
[求助] encounter 工具中 DB命令
发表于 2013-12-3 19:00:20 | 显示全部楼层
Solution
An fterm is a "formal terminal". Here is a comparison of fterms and terms:
“cells” have “fterms”
“insts” have “terms”
“terms” connect to “nets”
“nets” connect to “terms” and “fterms”
“fterms” are IO Pins as viewed by the top “cell”
“fterms” can also be the pins on a LEF library cell, as in “BUFX2”
Please look into the Database Access Command Diagram in EDI System Database Access Command Reference manual for clarification.
For example, if a Verilog file has:
module top (A, B...)
inst1 BUFX2 ( .a(A), .... )
end top
"A" is the fterm and "a" is the term. If you are referring to the pins of a library cell such as BUFX2, then you use "fterm". If you are referring to the pins of an instance of BUFX2 using "term".
http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY1JboMwAEXPkgNEtqECszQ2g0tKAgFCvUEE0ZR5ENDA6UMO0PeXT18PCLCvTZfikU5F16Y1iIFQEiRZFDkfUDtTF0OOFdfxIwPugNv7oSTwHwgE30Coby9JCEPNMgMdcurwT6zKEnQUELXd2OylAMR2NuqsIn-MMC9QhllcQpvN_DjJYvR-H6u2JIaWxzqzv9YZ35FECe79Hmf9HM7kuZ6eNPSFhSI5yHO4ZcV2PZ_C-3LlZfJzVNEt08qhbibPoBUrp4EHl9rcfJYv_ABcu2ty0FftZmJyeAERCXTn/dl3/d3/L2dBISEvZ0FBIS9nQSEh/#
发表于 2014-4-23 15:48:14 | 显示全部楼层
回复 2# farren
    赞
发表于 2016-1-25 18:00:23 | 显示全部楼层
I faced same problem.
发表于 2017-6-15 11:22:31 | 显示全部楼层
回复 2# farren
   赞!很有帮助!
GMT+8, 2025-12-26 23:26 , Processed in 0.013243 second(s), 2 queries , Gzip On, Redis On.
