查看: 1916|回复: 2
[原创] 一个分析代码,不缓存
发表于 2011-12-8 15:45:05 | 显示全部楼层 |阅读模式
module OutMod(
    rst,
clk,
    clkp,
    clkv,
    clkh,
Din,
max,
switch,
Dclk,
Dout
input          rst;
input          clk;
input          clkp;
input          clkv;
input          clkh;
input          max;
input          switch;
input[7:0]     Din;
output          Dclk;
output[8:0]     Dout;
reg[8:0]        Dout;
reg[2:0]        OutOrder;
reg             copy_v;
reg             copy_h;
reg             hen;
reg             Yen;
reg             frame_logo;
reg               time_en;
reg[1:0]          outByte;
reg               AnalysisEnd;
reg[8:0]             y_Num;
reg[9:0]             x_Num;
reg                  Byte_add;
reg[8:0]             yBuf;
reg[9:0]             xBufA;
reg[9:0]             xBufB;
reg[9:0]             y_out;
reg[9:0]             x_out;
reg[7:0]             max_Dbuf;
wire            Den_value;
wire            Add_en;
wire            Dclk;
wire            en_v;
wire            en_h;
wire            max_begin;
wire[10:0]      BxNum_sum;
wire[10:0]      ABNum_sum;
parameter     YUYV   =  1'b0;
parameter     S0   =  3'b000, S1   =  3'b001, S2   =  3'b010, S3   =  3'b011, S4   =  3'b100 ;
parameter     SS0  = 2'b00,  SS1   =   2'b01, SS2  =   2'b10, SS3  =  2'b11;
assign    Add_en    =  !Byte_add & y_Num[5];
assign    en_v      =  !copy_v & clkv;
assign    en_h      =  !copy_h & clkh;
assign    Dclk      =  Byte_add;
assign    Den_value =  ((x_Num[9:6] == 1'b0)||(x_Num[9:6] == 4'b1001))?  1'b0 : 1'b1;
assign    max_begin =  (Din >= max_Dbuf)? 1'b1 : 1'b0;
assign    BxNum_sum  =  xBufB + x_Num;
assign    ABNum_sum  =  xBufA + xBufB;
always @(posedge clkp) begin
    if(rst == 1'b0) begin
     OutOrder   <=  1'b0;   //
  frame_logo <= 1'b0;
end
else  begin
     copy_v  <=  clkv;
     if(en_v == 1'b1) begin
      frame_logo  <= !frame_logo;
      if((OutOrder[2] == 1'b1)||(switch == 1'b0))
       OutOrder  <=  1'b0;
   else
             OutOrder  <=  OutOrder + 1'b1;
     end
end
end
    if(clkv == 1'b0) begin
     y_Num <= 1'b0;
end
else begin
     copy_h <= clkh;
     if(en_h == 1'b1)
      y_Num <= y_Num + 1'b1;
end
if(clkh == 1'b0) begin
     x_Num <= 1'b0;
     Yen   <= 1'b0;
end
else  begin
     Yen   <= !Yen;
     if(Yen == YUYV)
         x_Num <= x_Num + 1'b1;
end
end
reg[7:0]      Reference;
        max_Dbuf  <=  1'b0;
        if(switch == 1'b0)
            Reference <=  max_Dbuf[7:1] + max_Dbuf[7:2];  // Refernce is 3/4 of max_Dbuf
end
else  begin
     if(Den_value == 1'b1) begin
      if(max_begin == 1'b1)
          max_Dbuf  <=  Din;
     end
end
end
reg[1:0]     CoordNum;
reg[1:0]     famerNum;
reg          two_en;
reg          AorB;
    if(en_h == 1'b1) begin
     CoordNum <= 1'b0;
     famerNum <= CoordNum;
  if((famerNum != CoordNum)&&(famerNum[0] != 1'b1))
      yBuf  <= y_Num;
  if(two_en== 1'b0)
            two_en  <=  famerNum[1];
        else
            two_en  <= |famerNum;
end
else if(AnalysisEnd == 1'b0) begin
     if(max == 1'b1) begin
      CoordNum <= CoordNum + !CoordNum[1];
      if(CoordNum == 1'b0) begin
                if(famerNum == 1'b0) begin     //  coordinate of the first appear point
                    xBufA  <= x_Num;
                    AorB   <= 1'b1;
                end
    else if({famerNum[1],two_en} == 2'b10) begin
        if(xBufA >= BxNum_sum[10:1]) begin     //  Coordinates exchange
      xBufA  <= x_Num;
      xBufB  <= xBufA;
      AorB   <= 1'b0;
     end
       end
////////////////////////////////////////////////////////// the up Part is to determine A/B
                else if(two_en == 1'b1)begin       //  coordinate of the first disappeared point
                    if(x_Num <= ABNum_sum[10:1]) begin
                        xBufA  <= x_Num;
      AorB   <= 1'b0;
     end
     else begin
         xBufB  <= x_Num;
      AorB   <= 1'b1;
     end
                end
   end
   else if({famerNum[1],two_en} != 2'b10) //
    xBufB <= x_Num;
  end
end
end
     AnalysisEnd  <=  1'b0;
        if(AnalysisEnd != 1'b0) begin
      if(OutOrder == 1'b0) begin
       x_out  <=  max_Dbuf;
    y_out  <= {frame_logo, max_Dbuf};
   end
         else begin
                x_out  <= (OutOrder[0] == 1'b1) ? xBufA : xBufB;
                y_out  <= (AorB == 1'b1) ? {frame_logo, yBuf} : {frame_logo, y_Num};
      end
     end
end
else if({en_h,AnalysisEnd} == 2'b10) begin
     if(OutOrder != 1'b0) begin
      if(OutOrder[1] != OutOrder[0])
             AnalysisEnd  <=  CoordNum[1] & famerNum[1];
         else if({two_en,CoordNum} == 3'b100)
    AnalysisEnd  <=   1'b1;
  end
end
end
     outByte  <=  1'b0;
end
else begin
     Byte_add  <= y_Num[5];
  if(Add_en == 1'b1) begin
            if(outByte == 2'b11)
          time_en  <=  1'b0;
   else begin
       time_en  <=  1'b1;
       outByte  <=  outByte + 1'b1;
   end
  end
end
end
     case(outByte)
      SS0 :  if(OutOrder == S1)
               Dout  <=  {y_out[9],8'hff};
       else
            Dout  <=  {y_out[9],6'b0, x_out[9:8]};
      SS1 :  if(OutOrder == S1)
       else
            Dout  <=  {y_out[9],x_out[7:0]};
      SS2 :  Dout  <=  {y_out[9],7'b0, y_out[8]};
      SS3 :  Dout  <=  {y_out[9],y_out[7:0]};
      default : ;
  endcase
end
end
endmodule
发表于 2011-12-9 20:25:32 | 显示全部楼层
分析啥的呢?
发表于 2012-2-26 14:08:31 | 显示全部楼层
Take a look, thanks.
GMT+8, 2025-12-30 02:24 , Processed in 0.017902 second(s), 5 queries , Gzip On, Redis On.
