查看: 2896|回复: 3
[求助] 关于 license
发表于 2011-11-28 17:51:39 | 显示全部楼层 |阅读模式
17:37:49 (lmgrd)   Please Note:
17:37:49 (lmgrd)
17:37:49 (lmgrd)   This log is intended for debug purposes only.
17:37:49 (lmgrd)   There are many details in licensing policies
17:37:49 (lmgrd)   that are not reported in the information logged
17:37:49 (lmgrd)   here, so if you use this log file for any kind
17:37:49 (lmgrd)   of usage reporting you will generally produce
17:37:49 (lmgrd)   incorrect results.
17:37:49 (lmgrd)
17:37:49 (lmgrd) -----------------------------------------------
17:37:49 (lmgrd)
17:37:49 (lmgrd)
17:37:49 (lmgrd) The TCP port number in the license, 5655, is already in use.
17:37:49 (lmgrd) Possible causes:
17:37:49 (lmgrd)    1) lmgrd is already running for this license.
17:37:49 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
17:37:49 (lmgrd)    3) Another process is using this port number (unlikely).
17:37:49 (lmgrd) Solutions:
17:37:49 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
17:37:49 (lmgrd)       license are not running.
17:37:49 (lmgrd)    2) You may have to wait for the OS to clear this port.
17:37:49 (lmgrd) Retrying for about 5 more minutes
[cool@localhost license]$ 17:38:07 (lmgrd) Still trying...
17:38:25 (lmgrd) Still trying...
17:38:43 (lmgrd) Still trying...
17:39:01 (lmgrd) Still trying...
17:39:19 (lmgrd) Still trying...
17:39:37 (lmgrd) Still trying...
17:39:55 (lmgrd) Still trying...
17:40:13 (lmgrd) Still trying...
17:40:31 (lmgrd) Still trying...
17:40:49 (lmgrd) Still trying...
17:41:08 (lmgrd) Still trying...
17:41:23 (lmgrd) Failed to open the TCP port number in the license.
 楼主| 发表于 2011-11-28 17:52:40 | 显示全部楼层
我是一个菜鸟 请各位大侠 关照  这个问题我已经纠结一天了 但是还是没找的问题所在 请大家多多指教
 楼主| 发表于 2011-11-28 17:53:29 | 显示全部楼层
[cool@localhost ~]$ cd /home/ic5141/share/license
[cool@localhost license]$ lmgrd -c license.dat
[cool@localhost license]$ source  .bashrc
bash: .bashrc: 没有那个文件或目录
[cool@localhost license]$ 17:37:49 (lmgrd) -----------------------------------------------
17:37:49 (lmgrd)
17:37:49 (lmgrd)
17:37:49 (lmgrd)
17:37:49 (lmgrd)
发表于 2014-3-17 14:39:54 | 显示全部楼层
还是没解决
GMT+8, 2025-12-15 00:41 , Processed in 0.022432 second(s), 7 queries , Gzip On, Redis On.
