查看: 5187|回复: 6
[讨论] VCS-2010 Ubuntu 安装问题
发表于 2011-11-25 21:34:08 | 显示全部楼层 |阅读模式
在本站下的VCS-2010.06-4不能安装,先是直接进入common文件夹安装,直接就报错,说是什么OS-specified的问题,然后又想了个办法,将common和linux文件夹压缩成tar格式,然后启动installer,把common和linux一起安装,但是又报出来一个错误,说是vcs.bz2 corrupted,选择了继续安装,最后还是报错,ERROR: Can not find vcs installation script /usr/synopsys/D-2010.06-4/VMS/admin/install.sh,搞了一整天已经崩溃,有在Ubuntu下安装成功的希望能够指教,不胜感激!!!!
 楼主| 发表于 2011-11-26 01:13:39 | 显示全部楼层
自己顶起来把!!
发表于 2011-12-2 20:08:36 | 显示全部楼层
yundao
use the release dir in the amd64,replace the same dir in the common
and install
发表于 2011-12-12 17:54:13 | 显示全部楼层
我的install.sh也不能安装啊
发表于 2012-5-6 17:08:11 | 显示全部楼层
怎么安装的呀
发表于 2012-5-12 14:12:29 | 显示全部楼层
Algorithm for usage of VCS 2011+ on CentOS 6.0+
Algorithm for usage of VCS 2011+ on CentOS 6.0+ =>
1. In "/etc/redhat-release"  being "root / sudo(if applicable)" ==>
    -> Comment the existing version using "#" character in the above file [without quotes]
    -> Enter the following : "CentOS release 5.7 (Final)" <- Without quotes as the very "First Line"
    -> Save and exit as root (NO re-boot is required)
    -> Start using the VCS 2011+ assuming proper license is available for that machine / (over)network
2. After sims complete, either being bored of VCS(or Synopsys in general) or job complete =>
    -> Replace the original CentOS version line in the above file as the very "First Line"
    -> Retain the CentOS release 5.7 (Final) line, but commented using "#" character and as second(2nd)
         line without quotes as well
    -> Save and exit as root (or sudo if applicable)
3. Use CentOS normally as usual
4. Don't ever "upgrade/update/install" anything in the present OS(6.0+) when above file has Centos 5.7[+/-]
     as entry, otherwise even the kernel will get overwritten if updated while having 5.7 as entry even
     through the OS might be 6.0+
5. If Kernel of Centos 6.0+ is overwritten with kernel of Centos 5.7+, NO issues : =>
    -> Using YUM,  "re-install" kernel to come back to Centos 6.0+(6.1/6.2/6.x) and reboot
    -> All is well :-D
6. Take extreme care of => "/etc/redhat-release" file in RHEL/CentOS environment !!!
7. Even RHEL engineers can use the above algorithm because => CentOS is a carbon copy of => RHEL
8. Always have the right CentOS/RHEL version of the OS in the => "/etc/redhat-release" file for any other work
9. Always use YUM to re-install the necessary software to come back to the original version
10. Editing => "/etc/redhat-release" file : before and after use of Synopsys TOOLS(VCS etc....) w.r.t the right OS version
      without "upgrade/update/install/re-install" will save us from "head-ache, dandruff and hair-fall" :-)
发表于 2013-6-24 12:01:34 | 显示全部楼层
把common/vcs.bz2 拷贝上级目录 cp common/vcs.bz2 ./ 试试.
网上很多包是分开打包的,解压后目录不一定对
今天重装时也出同样问题 记录一下.
GMT+8, 2025-12-30 01:27 , Processed in 0.021565 second(s), 6 queries , Gzip On, Redis On.
