发表于 2013-11-23 01:19:00
显示全部楼层
In window7, i used the VMware Fedoro-19 64bit/ CentOS 6.4 64bit system, also have the same problem.
/usr/local/mentor/calibre2011/ixl_cal_2011.2_34.26/bin/calibre: line 214: basename:命令找不到
WARNING: $CALIBRE_HOME and $MGC_HOME are different, using $CALIBRE_HOME=/usr/local/mentor/calibre2011/ixl_cal_2011.2_34.26
/usr/local/mentor/calibre2011/ixl_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 75: basename:命令找不到
/usr/local/mentor/calibre2011/ixl_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 131: tr:命令找不到
/usr/local/mentor/calibre2011/ixl_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 147: /usr/bin/: is a directory
/usr/local/mentor/calibre2011/ixl_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 148: /usr/bin/: is a directory
/usr/local/mentor/calibre2011/ixl_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 149: /usr/bin/: is a directory
/usr/local/mentor/calibre2011/ixl_cal_2011.2_34.26/pkgs/calibre_base/bin/calibre_env: line 150: /usr/bin/: is a directory
ERROR: Unknown system type: |
