楼主: ic_qiand
[2011-11-1][Mentor][Calibre X86 X64 Doc][2011.2_16.14][原创] Calibre一贴搞定...
发表于 2013-11-27 21:12:52 | 显示全部楼层
進入"calibre -gui" 畫面後, 跑"nmDRC"
選"cancel runset file"  一直出現下列訊息不知如何解決
//  Error: The following products could not be licensed sufficiently:
//  Error: - Calibre Interactive
发表于 2013-11-30 01:36:56 | 显示全部楼层
楼主您好!你受累了,感谢你完美的帖子!
我现在安装mentor AMS 2010.2a(win 版本)时遇到些许问题:
1.复制MenterKG.exe到安装路径,生成了LICENSE.TXT。
2.将LICENSE.TXT加入环境变量MGLS_LICENSE_FILE中。然后运行软件,只有ADMS组件显示窗口,其它的
eldo、EZwave等打不开啊。
你用过吗?能不能分享一下你的经验。
发表于 2013-12-6 16:14:46 | 显示全部楼层
装patch的时候是这个情况:
[root@106 x86_cal_2011.2_34.26]# ./patch_calibre2011_linux
[total hits/matching patterns/non-matching patterns]
43% bin/lmver : 0 changewarn : empty file: tmp/lockcdslmd - skipping
              error: failed to read+write: sfk - skipping
6574 files checked, 0 changed.
1 errors, 1 warnings occurred.
为什么会有一个error呢????
发表于 2013-12-6 23:52:50 | 显示全部楼层
学习下。。
发表于 2013-12-13 01:06:01 | 显示全部楼层
感謝大大分享 .
发表于 2013-12-15 13:07:42 | 显示全部楼层
安装了没成功。。。
发表于 2013-12-25 23:02:40 | 显示全部楼层
64位系统 ,进行运行lmlim1时显示:22:50:58 (lmgrd)   Please Note:
22:50:58 (lmgrd)
22:50:58 (lmgrd)   This log is intended for debug purposes only.
22:50:58 (lmgrd)   In order to capture accurate license
22:50:58 (lmgrd)   usage data into an organized repository,
22:50:58 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
22:50:58 (lmgrd)   software license administration  solution,
22:50:58 (lmgrd)   FLEXnet Manager, to  readily gain visibility
22:50:58 (lmgrd)   into license usage data and to create
22:50:58 (lmgrd)   insightful reports on critical information like
22:50:58 (lmgrd)   license availability and usage. FLEXnet Manager
22:50:58 (lmgrd)   can be fully automated to run these reports on
22:50:58 (lmgrd)   schedule and can be used to track license
22:50:58 (lmgrd)   servers and usage across a heterogeneous
22:50:58 (lmgrd)   network of servers including Windows NT, Linux
22:50:58 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
22:50:58 (lmgrd)   www.acresso.com for more details on how to
22:50:58 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
22:50:58 (lmgrd)   for your enterprise.
22:50:58 (lmgrd)
22:50:58 (lmgrd) -----------------------------------------------
22:50:58 (lmgrd)
22:50:58 (lmgrd)
22:50:58 (lmgrd) The TCP port number in the license, 1818, is already in use.
22:50:58 (lmgrd) Possible causes:
22:50:58 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
22:50:58 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
22:50:58 (lmgrd)    3) Another process is using this port number (unlikely).
22:50:58 (lmgrd) Solutions:
22:50:58 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
22:50:58 (lmgrd)       license are not running.
22:50:58 (lmgrd)    2) You may have to wait for the OS to clear this port.
22:50:58 (lmgrd) Retrying for about 5 more minutes
22:51:16 (lmgrd) Still trying...
22:51:34 (lmgrd) Still trying...
22:51:52 (lmgrd) Still trying...
22:52:10 (lmgrd) Still trying...
22:52:28 (lmgrd) Still trying...
22:52:46 (lmgrd) Still trying...
22:53:04 (lmgrd) Still trying...
22:53:22 (lmgrd) Still trying...
22:53:40 (lmgrd) Still trying...
22:53:58 (lmgrd) Still trying...
22:54:16 (lmgrd) Still trying...
22:54:31 (lmgrd) Failed to open the TCP port number in the license.
不知道为何,
ps 下看到有两个lmgrd .
重启后,直接root kill掉,然后再执行lmlim1,显示:22:50:32 (lmgrd)   Please Note:
22:50:32 (lmgrd)
22:50:32 (lmgrd)   This log is intended for debug purposes only.
22:50:32 (lmgrd)   In order to capture accurate license
22:50:32 (lmgrd)   usage data into an organized repository,
22:50:32 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
22:50:32 (lmgrd)   software license administration  solution,
22:50:32 (lmgrd)   FLEXnet Manager, to  readily gain visibility
22:50:32 (lmgrd)   into license usage data and to create
22:50:32 (lmgrd)   insightful reports on critical information like
22:50:32 (lmgrd)   license availability and usage. FLEXnet Manager
22:50:32 (lmgrd)   can be fully automated to run these reports on
22:50:32 (lmgrd)   schedule and can be used to track license
22:50:32 (lmgrd)   servers and usage across a heterogeneous
22:50:32 (lmgrd)   network of servers including Windows NT, Linux
22:50:32 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
22:50:32 (lmgrd)   www.acresso.com for more details on how to
22:50:32 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
22:50:32 (lmgrd)   for your enterprise.
22:50:32 (lmgrd)
22:50:32 (lmgrd) -----------------------------------------------
22:50:32 (lmgrd)
22:50:32 (lmgrd)
22:50:32 (lmgrd) FLEXnet Licensing (v11.6.1.0 build 66138 i86_re3) started on localhost.localdomain (linux) (12/25/2013)
22:50:32 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
22:50:32 (lmgrd) US Patents 5,390,297 and 5,671,412.
22:50:32 (lmgrd) World Wide Web:  http://www.acresso.com
22:50:32 (lmgrd) License file(s): /home/yaogang/EDA/calibre/ixl_cal_2011.2_34.26/license.dat
22:50:32 (lmgrd) lmgrd tcp-port 1818
22:50:32 (lmgrd) Starting vendor daemons ...
22:50:32 (lmgrd) Started mgcld (internet tcp_port 32867 pid 6487)
22:50:32 (mgcld) FLEXnet Licensing version v11.6.1.0 build 66138 i86_re3
22:50:32 (mgcld) Invalid license key (inconsistent authentication code)
22:50:32 (mgcld)        ==>FEATURE mgc_s mgcld 2023.120 25-dec-2023 uncounted \
        6E5307297EF6B9AAFBBF VENDOR_STRING=5A420C47 \
        HOSTID=000c29842168 SUPERSEDE ISSUER="Mentor Graphics 2013" \
        NOTICE="Licensed to yaog_zhull @ " ck=62 SN=59402 \
        SIGN2=83A4C0624ECC9ABA
22:50:32 (mgcld)        ==>FEATURE mentorall_s mgcld 2023.120 25-dec-2023 uncounted \
        AE73A7098FCC8740C69B VENDOR_STRING=AE9EEC76 \
        NOTICE="Licensed to yaog_zhull @ " ck=35 SN=59402 \
        SIGN2=13623014DFD078BA
22:50:32 (mgcld)        ==>FEATURE dftadvisor mgcld 2023.120 25-dec-2023 uncounted \
        7EB33739A41E1669DC51 VENDOR_STRING=673F70DB \
        NOTICE="Licensed to yaog_zhull @ " ck=4 SN=59402 \
        SIGN2=3FF83CEA4C32346C
22:50:32 (mgcld)        ==>FEATURE fastscan mgcld 2023.120 25-dec-2023 uncounted \
        0EB3B79982E0B53960BC VENDOR_STRING=66289318 \
        NOTICE="Licensed to yaog_zhull @ " ck=66 SN=59402 \
        SIGN2=7A0AF422DF3A2632
22:50:32 (mgcld)        ==>FEATURE flextest mgcld 2023.120 25-dec-2023 uncounted \
        AE138779C1FE498CDE2E VENDOR_STRING=32CF21AE \
        NOTICE="Licensed to yaog_zhull @ " ck=102 SN=59402 \
        SIGN2=F1AC4ED4AAC2EE0E
22:50:32 (mgcld)        ==>FEATURE lbistarchitect mgcld 2023.120 25-dec-2023 uncounted \
        2EF39729D16BCC117DC5 VENDOR_STRING=1A247798 \
        NOTICE="Licensed to yaog_zhull @ " ck=36 SN=59402 \
        SIGN2=7CB26F7480C0EE9C
22:50:32 (mgcld)        ==>FEATURE calcmpanalyzer mgcld 2023.120 25-dec-2023 uncounted \
        AE0337B93395C5FDB2C1 VENDOR_STRING=ED076D42 \
        NOTICE="Licensed to yaog_zhull @ " ck=54 SN=59402 \
        SIGN2=58289D24D50A04FA
22:50:32 (mgcld)        ==>FEATURE calcmpsimconx mgcld 2023.120 25-dec-2023 uncounted \
        5ED317E9DBC8A56DD3DD VENDOR_STRING=EF182D9A \
        NOTICE="Licensed to yaog_zhull @ " ck=130 SN=59402 \
        SIGN2=E14A62D08DA865F8
22:50:32 (mgcld)        ==>FEATURE caldesignrev mgcld 2023.120 25-dec-2023 uncounted \
        CE633759E43BF5F87BDC VENDOR_STRING=0FEF96EB \
        NOTICE="Licensed to yaog_zhull @ " ck=69 SN=59402 \
        SIGN2=02104D1C86747E40
22:50:32 (mgcld)        ==>FEATURE caldrclvseve mgcld 2023.120 25-dec-2023 uncounted \
        5ED397994B6A3066D0BF VENDOR_STRING=2EFB910D \
        NOTICE="Licensed to yaog_zhull @ " ck=68 SN=59402 \
        SIGN2=881CD4043E24E196
22:50:32 (mgcld)        ==>FEATURE calfracturec mgcld 2023.120 25-dec-2023 uncounted \
        DE03D79974834834C559 VENDOR_STRING=90799999 \
        NOTICE="Licensed to yaog_zhull @ " ck=20 SN=59402 \
        SIGN2=24EEE0EED0D2FD3C
22:50:32 (mgcld)        ==>FEATURE calfractureh mgcld 2023.120 25-dec-2023 uncounted \
        5E23871926AB8F7EE332 VENDOR_STRING=51EF5210 \
        NOTICE="Licensed to yaog_zhull @ " ck=228 SN=59402 \
        SIGN2=328C009CEF08B7A8
22:50:32 (mgcld)        ==>FEATURE calfracturej mgcld 2023.120 25-dec-2023 uncounted \
        6E3377799D92BC94DA6D VENDOR_STRING=AE7CC0FD \
        NOTICE="Licensed to yaog_zhull @ " ck=18 SN=59402 \
        SIGN2=18A007143ED6AFBE
22:50:32 (mgcld)        ==>FEATURE calfracturem mgcld 2023.120 25-dec-2023 uncounted \
        AEB3B7E98803BE1B15C2 VENDOR_STRING=A0F9B381 \
        NOTICE="Licensed to yaog_zhull @ " ck=51 SN=59402 \
        SIGN2=D2549FFC7348C36A
22:50:32 (mgcld)        ==>FEATURE calfracturet mgcld 2023.120 25-dec-2023 uncounted \
        CE73D779EABA0C5CB3B5 VENDOR_STRING=67089419 \
        NOTICE="Licensed to yaog_zhull @ " ck=125 SN=59402 \
        SIGN2=F51EA5006F92C3FA
22:50:32 (mgcld)        ==>FEATURE calfracturev mgcld 2023.120 25-dec-2023 uncounted \
        3EF3C779B414A7D52062 VENDOR_STRING=F1B5FFB9 \
        NOTICE="Licensed to yaog_zhull @ " ck=251 SN=59402 \
        SIGN2=AB625C0EAF1C8F46
22:50:32 (mgcld)        ==>FEATURE calibreadp mgcld 2023.120 25-dec-2023 uncounted \
        0E8307A99710F925346F VENDOR_STRING=FAF49E38 \
        NOTICE="Licensed to yaog_zhull @ " ck=219 SN=59402 \
        SIGN2=9C44BE3E61C62630
22:50:32 (mgcld)        ==>FEATURE calibreci mgcld 2023.120 25-dec-2023 uncounted \
        5E2387797E11E66B4C9F VENDOR_STRING=1D0B6FC1 \
        NOTICE="Licensed to yaog_zhull @ " ck=195 SN=59402 \
        SIGN2=EB58102634AC6676
22:50:32 (mgcld)        ==>FEATURE calibredrc mgcld 2023.120 25-dec-2023 uncounted \
        DE13F779916699695D88 VENDOR_STRING=5D3F9697 \
        NOTICE="Licensed to yaog_zhull @ " ck=9 SN=59402 \
        SIGN2=A49A19545B161292
22:50:32 (mgcld)        ==>FEATURE calibrehdrc mgcld 2023.120 25-dec-2023 uncounted \
        3EE30749D64179FCE51D VENDOR_STRING=13AF1355 \
        NOTICE="Licensed to yaog_zhull @ " ck=23 SN=59402 \
        SIGN2=74F802EA961249F4
22:50:32 (mgcld)        ==>FEATURE calibrehlvs mgcld 2023.120 25-dec-2023 uncounted \
        DEA3B7D99D38C16E11EE VENDOR_STRING=5D4F8AF7 \
        NOTICE="Licensed to yaog_zhull @ " ck=105 SN=59402 \
        SIGN2=E0BE1CBE55AE50DA
22:50:32 (mgcld)        ==>FEATURE calibrelfd mgcld 2023.120 25-dec-2023 uncounted \
        6EE3C70937281FA0A7D9 VENDOR_STRING=6E8FF81C \
        NOTICE="Licensed to yaog_zhull @ " ck=28 SN=59402 \
        SIGN2=365E51E479EC065E
22:50:32 (mgcld)        ==>FEATURE calibrelfdlite mgcld 2023.120 25-dec-2023 uncounted \
        7EA3B719D769E4F0F314 VENDOR_STRING=7ED03052 \
        NOTICE="Licensed to yaog_zhull @ " ck=41 SN=59402 \
        SIGN2=AE5669168DF43216
22:50:32 (mgcld)        ==>FEATURE calibrelfdmt mgcld 2023.120 25-dec-2023 uncounted \
        9E1307B920688A9DF2BB VENDOR_STRING=A94C9850 \
        NOTICE="Licensed to yaog_zhull @ " ck=16 SN=59402 \
        SIGN2=F26441A6DB66D76A
22:50:32 (mgcld)        ==>FEATURE calibrelv mgcld 2023.120 25-dec-2023 uncounted \
        8E63E7F93279CCF2514F VENDOR_STRING=D9B4D68F \
        NOTICE="Licensed to yaog_zhull @ " ck=46 SN=59402 \
        SIGN2=29A627AA896A979A
22:50:32 (mgcld)        ==>FEATURE calibrelvs mgcld 2023.120 25-dec-2023 uncounted \
        6E2357B9A1EBDD65E912 VENDOR_STRING=13C2D57A \
        NOTICE="Licensed to yaog_zhull @ " ck=7 SN=59402 \
        SIGN2=EB50B1DA355800F0
22:50:32 (mgcld)        ==>FEATURE calibreorc mgcld 2023.120 25-dec-2023 uncounted \
        AEF3773956A2C9DC5B80 VENDOR_STRING=5E1D4F6B \
        NOTICE="Licensed to yaog_zhull @ " ck=55 SN=59402 \
        SIGN2=611C89A65A540ADE
22:50:32 (mgcld)        ==>FEATURE calibreperc mgcld 2023.120 25-dec-2023 uncounted \
        4E6347D922684EB98F03 VENDOR_STRING=F283120B \
        NOTICE="Licensed to yaog_zhull @ " ck=49 SN=59402 \
        SIGN2=1CD0E01CBA2E6780
22:50:32 (mgcld)        ==>FEATURE calibrepvs_s mgcld 2023.120 25-dec-2023 uncounted \
        DEB37729EC1D450EC6FF VENDOR_STRING=AEF6DB09 \
        NOTICE="Licensed to yaog_zhull @ " ck=34 SN=59402 \
        SIGN2=D7D8C0E4504899F0
22:50:32 (mgcld)        ==>FEATURE calibreqdb mgcld 2023.120 25-dec-2023 uncounted \
        5EA3C7594BD5F51B5F98 VENDOR_STRING=63895852 \
        NOTICE="Licensed to yaog_zhull @ " ck=82 SN=59402 \
        SIGN2=30D0A490F1EEB1E6
22:50:32 (mgcld)        ==>FEATURE calibrexl mgcld 2023.120 25-dec-2023 uncounted \
        DE43D7A984285BEF7785 VENDOR_STRING=FD2CEE5A \
        NOTICE="Licensed to yaog_zhull @ " ck=63 SN=59402 \
        SIGN2=B1447366F9326312
22:50:32 (mgcld)        ==>FEATURE calibrexrc mgcld 2023.120 25-dec-2023 uncounted \
        DE134709F56F186861EA VENDOR_STRING=62F70E47 \
        NOTICE="Licensed to yaog_zhull @ " ck=247 SN=59402 \
        SIGN2=AB3CD2B42384FF64
22:50:32 (mgcld)        ==>FEATURE calibrexrcadms mgcld 2023.120 25-dec-2023 uncounted \
        5EE3E759D6930472A046 VENDOR_STRING=D5F2AA5F \
        NOTICE="Licensed to yaog_zhull @ " ck=15 SN=59402 \
        SIGN2=E610D0D01EBAA02A
22:50:32 (mgcld)        ==>FEATURE calibrexrccb mgcld 2023.120 25-dec-2023 uncounted \
        6EF3F729FD83E28518B2 VENDOR_STRING=C58FDE36 \
        SIGN2=2CEAFA8AB32C5F02
22:50:32 (mgcld)        ==>FEATURE calincrdrc mgcld 2023.120 25-dec-2023 uncounted \
        5ED32709C821967420EE VENDOR_STRING=0ADA2427 \
        NOTICE="Licensed to yaog_zhull @ " ck=39 SN=59402 \
        SIGN2=FC7EE858EA7EDF22
22:50:32 (mgcld)        ==>FEATURE calinteractive mgcld 2023.120 25-dec-2023 uncounted \
        BE130749BCA544545DB5 VENDOR_STRING=5AB479DB \
        NOTICE="Licensed to yaog_zhull @ " ck=1 SN=59402 \
        SIGN2=AC12A0567DFCF21C
22:50:32 (mgcld)        ==>FEATURE calmdpesvrf mgcld 2023.120 25-dec-2023 uncounted \
        7E330799C6479EE4A2A7 VENDOR_STRING=9DB9F129 \
        NOTICE="Licensed to yaog_zhull @ " ck=29 SN=59402 \
        SIGN2=9830D0365F9E0302
22:50:32 (mgcld)        ==>FEATURE calmdpmapi mgcld 2023.120 25-dec-2023 uncounted \
        3EC357093C3CA6B84884 VENDOR_STRING=98BED006 \
        NOTICE="Licensed to yaog_zhull @ " ck=253 SN=59402 \
        SIGN2=E0B848163874AF20
22:50:32 (mgcld)        ==>FEATURE calmdpmerge mgcld 2023.120 25-dec-2023 uncounted \
        EE83E7F9375EC1BDAC9E VENDOR_STRING=0EF85170 \
        NOTICE="Licensed to yaog_zhull @ " ck=111 SN=59402 \
        SIGN2=185AB352F54060B8
22:50:32 (mgcld)        ==>FEATURE calmdpview mgcld 2023.120 25-dec-2023 uncounted \
        8ED387C94299B59511E9 VENDOR_STRING=12AD362D \
        SIGN2=BE5CC9AEB2744E6C
22:50:32 (mgcld)        ==>FEATURE calmpcpro mgcld 2023.120 25-dec-2023 uncounted \
        EEA38779C95BE68DB5B9 VENDOR_STRING=F2BC1D1B \
        NOTICE="Licensed to yaog_zhull @ " ck=78 SN=59402 \
        SIGN2=83CE6C628BB40EB8
22:50:32 (mgcld)        ==>FEATURE calmtopcpro3 mgcld 2023.120 25-dec-2023 uncounted \
        DE23B7C93B6C35963DB3 VENDOR_STRING=C274FC71 \
        SIGN2=6596282ED908F452
22:50:32 (mgcld)        ==>FEATURE calnmopc mgcld 2023.120 25-dec-2023 uncounted \
        3E0327398FDF1A81BBA3 VENDOR_STRING=963385E3 \
        NOTICE="Licensed to yaog_zhull @ " ck=233 SN=59402 \
        SIGN2=BA3214124E2ED5BA
22:50:32 (mgcld)        ==>FEATURE calopcpro mgcld 2023.120 25-dec-2023 uncounted \
        0E03D7A922B090163292 VENDOR_STRING=5AF0FA94 \
        NOTICE="Licensed to yaog_zhull @ " ck=254 SN=59402 \
        SIGN2=027EF7F2826AC024
22:50:32 (mgcld)        ==>FEATURE calopcpro1 mgcld 2023.120 25-dec-2023 uncounted \
        CED337290B2DFDFCE517 VENDOR_STRING=5F1AC419 \
        NOTICE="Licensed to yaog_zhull @ " ck=103 SN=59402 \
        SIGN2=338CD73C62669794
22:50:32 (mgcld)        ==>FEATURE calopcsbar mgcld 2023.120 25-dec-2023 uncounted \
        2EA3C7F96D9FD115F9AA VENDOR_STRING=9DDB869C \
        SIGN2=1D2E0D90947A3612
22:50:32 (mgcld)        ==>FEATURE calopcverify mgcld 2023.120 25-dec-2023 uncounted \
        AEF3D7E9A6BD2D914B57 VENDOR_STRING=050BDF67 \
        SIGN2=0AA863B29A4EDFE8
22:50:32 (mgcld)        ==>FEATURE caltdopc mgcld 2023.120 25-dec-2023 uncounted \
        2E331779536CE44D1F21 VENDOR_STRING=79503FF1 \
        NOTICE="Licensed to yaog_zhull @ " ck=180 SN=59402 \
        SIGN2=87764248A7FA43A2
22:50:32 (mgcld)        ==>FEATURE calworkbench mgcld 2023.120 25-dec-2023 uncounted \
        1E2357091DFA22157462 VENDOR_STRING=FD8130A0 \
        NOTICE="Licensed to yaog_zhull @ " ck=213 SN=59402 \
        SIGN2=D42811CE55FC7464
22:50:32 (mgcld)        ==>FEATURE calyieldanalyze mgcld 2023.120 25-dec-2023 uncounted \
        8EC367B93703E04B1991 VENDOR_STRING=1A569AB3 \
        NOTICE="Licensed to yaog_zhull @ " ck=212 SN=59402 \
        SIGN2=AE74417055E2A924
22:50:32 (mgcld)        ==>FEATURE calyieldenhance mgcld 2023.120 25-dec-2023 uncounted \
        8E83C7B9A88B34387719 VENDOR_STRING=9163A20B \
        NOTICE="Licensed to yaog_zhull @ " ck=237 SN=59402 \
        SIGN2=D366186A370CFBD8
22:50:32 (mgcld)        ==>FEATURE calyieldserver mgcld 2023.120 25-dec-2023 uncounted \
        DEA36709D0801BD89BDC VENDOR_STRING=6A067694 \
        SIGN2=2CB298C63CB264AC
22:50:32 (mgcld)        ==>FEATURE ictrace mgcld 2023.120 25-dec-2023 uncounted \
        2EC3476928C49829D33E VENDOR_STRING=ED22FCE2 \
        NOTICE="Licensed to yaog_zhull @ " ck=6 SN=59402 \
        SIGN2=3B9A1F2E2690CF7C
22:50:32 (mgcld)        ==>FEATURE ictrace3 mgcld 2023.120 25-dec-2023 uncounted \
        6E1397792DFE4EEFD7A3 VENDOR_STRING=669361A6 \
        NOTICE="Licensed to yaog_zhull @ " ck=37 SN=59402 \
        SIGN2=7AF6A8F8B7D6D246
22:50:32 (mgcld)        ==>FEATURE xcalibrate mgcld 2023.120 25-dec-2023 uncounted \
        6ED307F933866B333982 VENDOR_STRING=CD099971 \
        NOTICE="Licensed to yaog_zhull @ " ck=21 SN=59402 \
        SIGN2=95704A5A261AB16E
22:50:32 (mgcld) License server system started on localhost.localdomain
22:50:32 (mgcld) No features to serve, exiting
22:50:32 (mgcld) EXITING DUE TO SIGNAL 36 Exit reason 4
22:50:32 (lmgrd) mgcld exited with status 36 (No features to serve)
22:50:32 (lmgrd) mgcld daemon found no features.  Please correct
22:50:32 (lmgrd) license file and re-start daemons.
22:50:32 (lmgrd)
22:50:32 (lmgrd) This may be due to the fact that you are using
22:50:32 (lmgrd) a different license file from the one you expect.
22:50:32 (lmgrd) Check to make sure that:
22:50:32 (lmgrd) /home/yaogang/EDA/calibre/ixl_cal_2011.2_34.26/license.dat
22:50:32 (lmgrd) is the license file you want to use.
求大侠帮助解决:
发表于 2013-12-25 23:04:29 | 显示全部楼层
问题补充:系统AS4 ,win7下虚拟机, calibre为64位。
发表于 2014-1-7 15:18:00 | 显示全部楼层
謝謝分享
試試看了
发表于 2014-1-13 16:12:34 | 显示全部楼层
好帖子必须要支持一下 啊,还在继续探索中,用的ubuntu系统安装,总是提示证书错误!
GMT+8, 2025-12-18 22:54 , Processed in 0.020103 second(s), 5 queries , Gzip On, Redis On.
