楼主: ic_qiand
[2011-11-1][Mentor][Calibre X86 X64 Doc][2011.2_16.14][原创] Calibre一贴搞定...
发表于 2013-9-26 21:24:54 | 显示全部楼层
楼主是个大好人啊
发表于 2013-9-29 22:36:43 | 显示全部楼层
G感谢楼主分享,感谢3楼吐血教程!
发表于 2013-10-17 10:25:50 | 显示全部楼层
楼主太热心了,十分强大
发表于 2013-10-17 11:06:16 | 显示全部楼层
下载好麻烦啊。。
发表于 2013-10-19 22:06:11 | 显示全部楼层
回复 1# ic_qiand
请教楼主,有下面错误的解决办法吗?谢谢!
   WARNING: Calibre software tree not set, using software version at: /gxldata/Mentor/Calibre/x86_cal_2011.2_34.26
Application initialization failed: Can't find a usable init.tcl in the following directories:
    :/gxldata/Mentor/Calibre/x86_cal_2011.2_34.26:/gxldata/Mentor/Calibre/x86_cal_2011.2_34.26/pkgs/icv_comp/8.4/lib/tcl8.4 /usr/local/lib/tcl /gxldata/Mentor/Calibre/x86_cal_2011.2_34.26/pkgs/icv/lib/tcl8.4 /gxldata/Mentor/Calibre/x86_cal_2011.2_34.26/pkgs/lib/tcl8.4 /gxldata/Mentor/Calibre/x86_cal_2011.2_34.26/pkgs/icv/library /gxldata/Mentor/Calibre/x86_cal_2011.2_34.26/pkgs/library /gxldata/Mentor/Calibre/x86_cal_2011.2_34.26/pkgs/tcl8.4.9/library /gxldata/Mentor/Calibre/x86_cal_2011.2_34.26/tcl8.4.9/library :/gxldata/Mentor/Calibre/x86_cal_2011.2_34.26:/gxldata/Mentor/Calibre/x86_cal_2011.2_34.26/pkgs/icv_comp/8.4/lib/tcl
This probably means that Tcl wasn't installed properly.
发表于 2013-10-20 14:00:07 | 显示全部楼层
回复 1# ic_qiand
   hello,
发表于 2013-10-20 14:02:04 | 显示全部楼层
回复 606# siddm
   hi,
发表于 2013-10-20 14:04:10 | 显示全部楼层
回复 603# rororo20
can u plz give pan baidu or115.com links for QUESTA ADMS?
发表于 2013-10-20 14:05:14 | 显示全部楼层
回复 601# andeliev
SOMEONEHAVING LINK FOR LIBRARY DEVELOPMENT
发表于 2013-10-20 14:06:13 | 显示全部楼层
回复 605# 桓桓
CANANY ONE GIVE REFERENCES FOR ANALOG VERIFICATION?
GMT+8, 2025-10-8 03:50 , Processed in 0.017886 second(s), 3 queries , Gzip On, Redis On.
