查看: 4275|回复: 1
[求助] hspicerf 不能仿真verilog-A是怎么回事呢?
发表于 2011-10-14 10:59:49 | 显示全部楼层 |阅读模式
想用hspicerf仿真PLL的相位噪声,根据教程一步步来,但是发现不能仿真啊,大侠们看看是什么原因啊!
HSPICE RF -- C-2009.03 (Feb 24 2009)
Copyright (C) 2009 Synopsys,Inc. All rights reserved.
This software and the associated documentation are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
hspicerf 32-bit version C-2009.03 (Feb 24 2009 12:24:03)
machine info: Microsoft Windows XP Professional Server 4.0 Service Pack 3
(Build 2600) 586 on WWW-90EE5476024
current time: 10:53:51 10/14/2011
command line: hspicerf e:\hspicesample\pll_hspicerf_simu\pll.sp
    During .hdl command processing: loading Verilog-A modules from
        'e:\hspicesample\pll_hspicerf_simu\PLL.va'.
hsp-vacomp:
hsp-vacomp: Invoking the Verilog-A compiler for 'e:\hspicesample\pll_hspicerf_simu\PLL.va'
hsp-vacomp: Synopsys HSPICE Verilog-A Compiler Version 1.75.100.101408.
hsp-vacomp: Copyright (C) 2008 Synopsys, Inc. All Rights Reserved.
hsp-vacomp:
hsp-vacomp:  lic:
hsp-vacomp:  lic: FLEXlm: v8.5b
hsp-vacomp:  lic: USER:   Administrator        HOSTNAME: www-90ee5476024
hsp-vacomp:  lic: HOSTID: "001cc0a878c0 005056c00001 005056c00008" PID:      5772
hsp-vacomp:  lic: Using FLEXlm license file:
hsp-vacomp:  lic: 27000@elena
hsp-vacomp:  lic: Checkout 1 hspiceva
hsp-vacomp:  lic: License/Maintenance for hspiceva will expire on 31-dec-2020/2007.9
hsp-vacomp:  lic: NODE LOCKED license on hostid "001cc0a878c0 005056c00001 005056c00008"
hsp-vacomp:  lic:
hsp-vacomp:  lic: Release hspiceva token(s)
Error:     CML file does not exist
         'C:\Documents and Settings\Administrator\hsp-model-cache\1.75\e\\hspicesample\pll_hspicerf_simu\\lib.win32\PLL.cml'
发表于 2011-10-23 01:24:09 | 显示全部楼层
路径不对嘛,不是很明显的提示吗
GMT+8, 2025-12-17 02:30 , Processed in 0.023408 second(s), 5 queries , Gzip On, Redis On.
