查看: 7230|回复: 13
[求助] how to merge GDS through icfb
发表于 2011-10-13 11:31:41 | 显示全部楼层 |阅读模式
Hi, all
I need to export the GDS of my digital part. However, the GDS exported through ICC doen't contains all the infos because of the incomplete Milkyway database. and now I wanna  merge the GDS through GDS, could anyone give me some detailed instructions? the more specified, the better.
thanks in advance.
发表于 2011-10-13 20:15:04 | 显示全部楼层
gds merging has several way :
1. use icfb ,  first streamin all reference library gds , then streamin in top gds ,
choose  reference lib (no merge) options when streamin , then streamout , ok
2. use -depth >20  when streamout from icc  ,  that is , merge all full gds layer
in all reference library to combined into full gds
3. use -merge from edi when streamOut , -merge all gds
4. use calibredrv , layoutMerge command , can do it ,
i always use 1) icfb to merge , which is traditional and not error prone ,
 楼主| 发表于 2011-10-13 22:36:17 | 显示全部楼层
回复 2# icfbicfb
    thank icfbicfb again.
发表于 2012-8-26 11:39:25 | 显示全部楼层
回复 2# icfbicfb
hi icfbicfb,
    I use the icfb to merge according to what you said. But the gds I write out has no the information of the layers.
Can you give me some advice?
发表于 2012-8-29 21:26:59 | 显示全部楼层
回复 4# zuoyedeyu
    maybe  some files needed but you did not added,like techfile.tf or display.drf  , or you have added, but did not attached it.
发表于 2012-8-29 23:28:35 | 显示全部楼层
回复 5# e07610230
    I know it. The option I set is wrong, and my techfile.tf also has some problems. Thanks.
发表于 2014-4-22 10:10:20 | 显示全部楼层
I have meet some problems when I stream in the top gds to reference full gds. The stand cells in top gds have covered the same cells in reference lib, so that the merge is failed. I think it is my mistake, but how?
发表于 2014-4-22 10:45:35 | 显示全部楼层
回复 7# daipeng
   你可以说中文来描述问题
发表于 2014-11-3 14:48:55 | 显示全部楼层
learning !!!
发表于 2015-1-7 15:42:46 | 显示全部楼层
回复 2# icfbicfb
   版主,想请教,具体用icfb merge GDS的脚本流程。我现在是如下做的:1. 用xstream将cell、io的gds都stream in,再将top的gds stream in,再将dummy metal和dummy poly的gds stream in。
2. stream out出gds。但生成的gds,并没有将dummy给merge进去。
想问问, 在stream的时候,要开哪些参数么?版主说的“choose  reference lib (no merge) options”,用xstream脚本的话,是设置哪个参数?
GMT+8, 2025-10-20 05:45 , Processed in 0.017242 second(s), 3 queries , Gzip On, Redis On.
