查看: 8054|回复: 14
安装mmsim61时出现installscape错误怎么办
发表于 2011-9-16 23:23:18 | 显示全部楼层 |阅读模式
我在redhat linux AS4下安装了ic5141,随后安装mmsim61时出现以下错误怎么办?
Extracting InstallScape version
for platform lnx86 in /home/install/mmsim
./SETUP.SH: line 814: uncompress: command not found
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0.0
If you do not see the InstallScape console
window or the it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/home/install/mmsim/iscape/bin/iscape.sh /home/install/mmsim/MMSIM61_lnx86.Base/CDROM1:::/home/eda/cadence/mmsim61
/bin/sh: /home/install/mmsim/iscape/bin/iscape.sh: No such file or directory
发表于 2011-9-17 00:58:28 | 显示全部楼层
1) 好像系统没有uncompress命令。你应设好它的路径或装一个;
2)你没装iscape或没设好路径。
 楼主| 发表于 2011-9-17 01:02:43 | 显示全部楼层
已解决:ln -s /bin/gzip /bin/uncompress
发表于 2011-11-13 10:15:31 | 显示全部楼层
原来是这么回事
发表于 2012-8-17 15:59:30 | 显示全部楼层
iscape如何装啊?
发表于 2013-10-2 20:51:28 | 显示全部楼层
学习安装mmsim中
发表于 2013-10-18 10:28:34 | 显示全部楼层
学习中
发表于 2015-4-13 14:42:40 | 显示全部楼层
回复 3# zzyhpu
   多谢,这个方法可用,已解决
发表于 2015-10-19 21:26:01 | 显示全部楼层
Thank you.
发表于 2016-6-23 15:53:14 | 显示全部楼层
多谢,成功解决
GMT+8, 2025-12-21 20:29 , Processed in 0.025458 second(s), 7 queries , Gzip On, Redis On.
