查看: 3813|回复: 3
[求助] fanout violation when synthesis.
发表于 2011-8-30 18:22:20 | 显示全部楼层 |阅读模式
Hi,
suppose the given case:
the external system reset port rst_n is a high-fanout-net, however, when doing synthesis, using the constraints below
(1) I don't set_ideal_network attributes on rst_n, letting DC build the buffer tree.
(2) set_max_fanout 30 [get_ports rst_n]
when report_constraint -all_violators -max_fanout, violations occur on the port rst_n, showing a negtive slack.
Why doesn't this happen, and how do I fix the violation if I fix this during synthesis( not when implementating the layout).
Thanks in advance.
发表于 2011-8-30 22:56:46 | 显示全部楼层
did you set driven cell on rst_n?
 楼主| 发表于 2011-8-30 23:19:22 | 显示全部楼层
回复 2# 陈涛
    No driven cell is set.
Now I think it's violated by the tight max_fanout constraint. I checked the library and found that the max_fanout of the output_pin of the
rst_n PAD is 600. In this case the slack is 600 - 150 = 450, which is a positive slack.And I could ignore this violation by remove the tight max_fanout constraint, or loosen the constraint.
Is this right?
Thanks in advance.
 楼主| 发表于 2011-8-30 23:44:47 | 显示全部楼层
回复 2# 陈涛
No driving cell is set.
I checked the library and found that the output pins of the rst_n PAD has a max_fanout attribute of 600, In this case, the slack would be
600 - 160 > 0, which is a positive slack.
and I could remove the tight max_fanout constraint or loosen the constraint to get a no-violations result, right?
yeah?
thanks in advance.
GMT+8, 2025-12-27 11:08 , Processed in 0.016201 second(s), 6 queries , Gzip On, Redis On.
