楼主: wjx197733
[求助] drc检查提示off grid
发表于 2011-9-3 14:37:30 | 显示全部楼层
上面说的是在mask制作时的
发表于 2011-9-5 13:57:08 | 显示全部楼层
MASK的精度不一样,格点不一样
发表于 2011-9-6 08:46:20 | 显示全部楼层
"off-grid" is a very "serious" problem, specially for Deep-Sub-Microm process.
It will cause DRC violations and when you make the mask, it will (sometimes) require different grade of mask material and increase your manufacturing cost.
发表于 2011-9-6 23:59:10 | 显示全部楼层
off manufacturing grid ( that is offgrid in calibre drc check ) is a real DRC error ,
should fix ,
since sometimes the offgrid error is not important if it have large space or not result in
shorts or open , but it can results in shorts or open case ,
so please fix it !!!
in icfb :  snap to grid in option before StreamOut
发表于 2011-9-16 14:14:56 | 显示全部楼层
foundry一般留了20%餘量,不會有問題,但是最好還是清掉吧,很簡單花不了多少時間。
发表于 2011-9-18 14:50:31 | 显示全部楼层
drc错误还是需要清理的,除非你和foundry确认
发表于 2011-9-19 14:51:20 | 显示全部楼层
很重要,最好是把OFFGRID 错误清除掉
发表于 2011-10-14 13:49:02 | 显示全部楼层
接触孔还从来没遇到过offgrid额。不过这错得清吧。。除非foundry同意。
发表于 2012-3-20 18:04:37 | 显示全部楼层
看FAB的要求了。
发表于 2015-3-21 00:12:16 | 显示全部楼层
  请教, 大侠有没有实际见过由于off grid出问题的情况,如果有问题会出现什么样的问题?
GMT+8, 2025-12-27 11:05 , Processed in 0.018248 second(s), 3 queries , Gzip On, Redis On.
