发表于 2012-8-29 13:04:08
显示全部楼层
回复 12# sudezhao
You can try many methods!
(1) In case the command (sudo apt-get install sch) doesn't work on your ubuntu or linux!
(2) Try this command ==> sudo apt-get update && apt-get install sch
If still unable to install, try it using ROOT account!
(3) Btw, after the updates, make sure those required files are mark (or tick) as executable.
It is important! Just right-click to make sure it is executable. |
