查看: 8528|回复: 38
A precision curvature-compensated CMOS bandgap reference
发表于 2006-11-2 18:41:30 | 显示全部楼层 |阅读模式
A precision curvature-compensated CMOS bandgap reference.pdf
1.41 MB, 下载次数: 303 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-11-2 18:48:07 | 显示全部楼层
Good one
I like it
发表于 2006-11-2 18:50:36 | 显示全部楼层
Forget to say thanks
Thanks
发表于 2006-11-4 10:46:20 | 显示全部楼层
试一下购买  ,不过还是谢了
发表于 2006-12-24 22:37:47 | 显示全部楼层
:o
发表于 2006-12-24 22:38:39 | 显示全部楼层
发表于 2007-1-25 12:49:08 | 显示全部楼层
下来看看,谢谢
发表于 2007-1-25 15:33:05 | 显示全部楼层
1983,ieee
Ab.~tract—A precision curvature-compensated switched-capacitor bandgap
reference is described which employs a standard digital CMOS process
and achieves temperature stability significantly lower than has previously
been reported for CMOS circuits. The theoretically achievable temperature
coefficient approaches 10 ppm/ 0 C over the commercial temperature
range utilizing a straightforward room temperature trim procedure. Experimental
data from monolithic prototype samples are presented which are
consistent with theoretical predictions. The experimental prototype circuit
occupies 3500 milsz and dissipates 12 mWwith+5Vpowersupplies,The
proposedreferenceis helieved to be suited for use in monolithic data
acquisition systems with resolutions of 10 to 12 bits.
发表于 2007-3-18 16:29:43 | 显示全部楼层
终于找到!!!
含泪感谢!!!!!
发表于 2007-3-18 17:37:53 | 显示全部楼层
thanks for your information....
thanks.....
GMT+8, 2025-12-26 15:04 , Processed in 0.037229 second(s), 7 queries , Gzip On, Redis On.
