查看: 6433|回复: 2
[求助] How to use VCRES in analoglib
发表于 2011-5-31 16:45:52 | 显示全部楼层 |阅读模式
Hi,guys,
does anybody know how to set parameters for the vcres element from analogLib? when i instantiate it and open its properties, there are no fields under CDF parameters. also when running simulations, HspiceD complains that no appropriate views are found for it. other elements like vdc have no such problem. is there something special that has to be done to get vcres to work? thanks.
发表于 2012-2-28 18:23:20 | 显示全部楼层
加入hspice 环境。
1. cshrc 加入 setenv CDS_LOAD_ENV CSF
2. cdsinit 加入 load ("xx/hspice.ile")
发表于 2013-12-6 20:14:57 | 显示全部楼层
choose its symbol then Edit--Properities--Tools Filter then choose all blanks.
GMT+8, 2025-12-26 05:15 , Processed in 0.028349 second(s), 7 queries , Gzip On, Redis On.
