查看: 13325|回复: 11
[求助] 关于Noise-Aware PLL的仿真
发表于 2011-5-30 17:35:32 | 显示全部楼层 |阅读模式
Hi all
我在使用cadence的ppv模型仿真PLL的jitter,瞬态仿真完成后,PLL noise PSD输出如下图所示。
图中的period jitter是不是应该为long term的RMS period Jitter, 而phase jitter我倒是没有看到有文章中提到。
有知道的么?
 楼主| 发表于 2011-5-30 21:28:01 | 显示全部楼层
这是图形,phase jitter什么意思?
PSD
PSD
 楼主| 发表于 2011-5-31 09:50:49 | 显示全部楼层
原来phase jitter是phase noise在指定频率内的积分值
难道这两个仿真出来的值,一个是瞬态的jitter即deterministic jitter, 另一个是random jitter由noise造成的?
Phase Jitter – Phase Noise Integration.
For many communications applications, the total noise power over a specific range of frequencies – not the shape (as shown in figure 12) is the primary concern. In order to determine the power over the frequency range (bandwidth), the time domain signal must be analyzed in the frequency domain, and then reconstructed in the time domain into an rms value with the unwanted frequencies excluded. This may be done by converting L(f) back to Sϕ(f) over the bandwidth in question, integrating and performing some additional calculations. The result is an rms value for ϕ(t). The result may be expressed in dB,  adians,
unit intervals, or seconds. The value, in seconds, represents 1 standard deviation of phase jitter contributed by the noise in the defined bandwidth. Figure 13 graphically displays the integrated area in green. The bandwidth for the integration in this example is 500 to 10000Hz..
 楼主| 发表于 2011-5-31 09:54:32 | 显示全部楼层
total jitter 是这两个加一起?
发表于 2012-12-29 23:09:28 | 显示全部楼层
您好,那个noise aware这个专门仿pll的软件,你有吗?  如果有的话  能不能传给我下?
谢谢
 楼主| 发表于 2012-12-31 11:11:41 | 显示全部楼层
cadence 自带的,不是独立的软件
发表于 2013-1-3 19:28:16 | 显示全部楼层
回复 6# stoneduan
    o   那我安装的IC614,mmsim10.1后怎么会没有这个Noise-Aware
谢谢
发表于 2013-1-4 21:47:31 | 显示全部楼层
请问这个对PLL能仿的正确吗?
发表于 2013-1-6 17:22:01 | 显示全部楼层
形似而已,没什么实际用处。
发表于 2016-8-17 09:15:40 | 显示全部楼层
learning !!!
GMT+8, 2025-12-29 01:25 , Processed in 0.024179 second(s), 7 queries , Gzip On, Redis On.
