查看: 5941|回复: 5
大版主还有一个timing violation问题想请问你!!
发表于 2005-9-15 12:29:46 | 显示全部楼层 |阅读模式
对于设计中的异步信号,因为它的变化沿有可能与时钟同时变化,这时会出现一些timing violation的信息,请问这对设计有影响么?是不是要修正呢?
DFT后仿真显示的违背信息:
Warning!  Timing violation
$setuphold<setup>( posedge CK &&& RN&~TE:688505675 NS, negedge D:688505674890 PS,  0.27 : 270 PS,  -0.06 : -60 PS );  File: ./smic25.v, line = 7583       Scope:system_check_stimulus_design.top_process.top_selftest1.testout1.Txd_Ack_r1_reg
Time: 688505675 NS
发表于 2005-9-15 14:57:26 | 显示全部楼层
这个不用管。
你可以用set_false_path来去掉这种时序检查。
但在接口设计上你要严格按异步接口的方法来做,否则会采样错误。
 楼主| 发表于 2005-9-15 17:17:05 | 显示全部楼层
你说的是在DC里面用set_false_path指令是么?
DC里面都是这样用的呀!!
 楼主| 发表于 2005-9-15 18:51:40 | 显示全部楼层
DC出来和DFT出来的都没有时序违背的呀!!
大版主,请给我确认一下
发表于 2005-9-17 01:53:47 | 显示全部楼层
If you have an asynchronous path, say signal X is sent from clock domain A,
first sampled to Y in clock domain B, then sampled again to Z in clock domain B,
from X to Y is asynchronous,
In DC and STA, you need to set_false_path -from X -to Y, then any timing violation
from X to Y would not be reported;
In simulation with timing, the simulator does not know X to Y is a false
path, so it reports errors. It is fine because you know it is an
asynchronous path and Y is not used anywhere else but at Z.
发表于 2011-12-26 16:51:57 | 显示全部楼层
还是没搞清。
GMT+8, 2025-12-21 09:26 , Processed in 0.021122 second(s), 7 queries , Gzip On, Redis On.
