查看: 9789|回复: 24
[资料] 一篇2011年TCASII低功耗的cap-free的LDO设计
发表于 2011-5-2 23:19:14 | 显示全部楼层 |阅读模式
不知道有人发过没的
篇名:Dynamic Bias-Current Boosting Technique for Ultralow-Power Low-Dropout Regulator in Biomedical Applications
摘要:
Abstract—A dynamic bias-current boosting technique that concurrently enables ultralow-power operation and fast-transient behavior is presented in this brief. It is applied to an ultralow-power output-capacitor-free  low-dropout  regulator  (LDO)  to  demonstrate  the  bandwidth  extension  provided  during  the  transient periods.  The  proposed  LDO  is  capable  of  providing  50  mA  of output current with a minimum dropout voltage of 0.1 V. The ultralow-power  LDO  is implemented  in  a commercial  0.13-µm CMOS process, with power consumption of 1.20 µW only. Experimental  results  verify  that  both  the  load-  and  line-transient responses of the proposed LDO are significantly improved, and the settling times during load and line transients are shortened by as much as 33 and 3 times, respectively.
abbr_654ae80c95014cbd654f7790c1183d57.pdf (460.96 KB , 下载次数: 405 )
发表于 2011-5-3 00:40:03 | 显示全部楼层
感謝分享壓
发表于 2011-5-3 13:16:21 | 显示全部楼层
看看啊
呵呵
发表于 2011-5-3 17:02:54 | 显示全部楼层
回复 1# refunok
    谢谢,
发表于 2011-5-3 19:45:12 | 显示全部楼层
学习一下!
发表于 2011-5-7 15:24:08 | 显示全部楼层
看看这篇怎样。
发表于 2011-5-21 18:18:02 | 显示全部楼层
谢谢!!!!!!
发表于 2011-5-22 16:01:17 | 显示全部楼层
Thanks a lot for the sharing!!!
发表于 2011-5-30 16:16:51 | 显示全部楼层
Thanks for your sharing!!!Good..
发表于 2011-7-8 20:28:01 | 显示全部楼层
nice...
GMT+8, 2025-12-15 20:15 , Processed in 0.028609 second(s), 8 queries , Gzip On, Redis On.
