查看: 6496|回复: 12
[讨论] SENTAURUS tcad2000安装问题,求教
发表于 2011-4-28 08:57:08 | 显示全部楼层 |阅读模式
按你的方法不行呀?大哥,前面所有的安装都成功了,可是到最后运行时显示下面的信息,求高手帮助!
下面的信息说LICENSE KEY 和DATA不匹配,但是完整性检查没有任何问题,都是参考了N位大哥的教程!
晕死,有没有高手呀?我的VM7。1,LINUX企业版5。1
***                         Sentaurus Workbench                          ***
***                          Version D-2010.03                           ***
***                        (1.6, ia32, linux_gnu)                        ***
***                       Copyright (C) 1994-2010                        ***
***                            Synopsys, Inc.                            ***
***  This software and the associated documentation are confidential     ***
***  and proprietary to Synopsys, Inc.  Your use or disclosure of this   ***
***  software is subject to the terms and conditions of a written        ***
***  license agreement between you, or your company, and Synopsys, Inc.  ***
License checkout failed: Invalid (inconsistent) license key.
The license key and data for the feature do not match.
This usually happens when a license file has been altered.
Feature:       swb_all
License path:  /home/user/synopsys/license/synopsys.dat
FLEXnet Licensing error:-8,130
For further information, refer to the FLEXnet Licensing End User Guide,
available
        * feature is "swb_all"
        * version is "2009.06"
        * server name is "<localhost>"
        * daemon is "snpslmd"
        * code is "5D8EE6A66E549307FB6C"
        * expiry date is "31-dec-2019"
        * STROOT is "/home/user/synopsys/D_2010.03/bin/.."
        * hostname is "localhost.localdomain"
        * display is "/dev/pts/2"
        * user is "root"
发表于 2011-4-28 09:02:23 | 显示全部楼层
还是你license出了问题!!!
重新生成一个license,尤其是改头文件那块,注意<localhost>的括号一定要去掉!!!
发表于 2011-6-11 14:09:56 | 显示全部楼层
hao yong ma ??
发表于 2011-9-11 15:31:22 | 显示全部楼层
不难安装吧
发表于 2011-9-11 20:46:36 | 显示全部楼层
回复 1# hokee
    co-ask
发表于 2011-9-11 20:50:47 | 显示全部楼层
回复 2# wanghds
    THanks a lot
发表于 2011-9-11 20:57:13 | 显示全部楼层
回复 6# wayneweiguo
    Thank you so much
发表于 2011-9-11 21:02:06 | 显示全部楼层
Thank you
发表于 2011-10-25 13:06:51 | 显示全部楼层
好东西,多谢分享。
发表于 2011-10-31 19:41:24 | 显示全部楼层
怎么安装
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 16:20 , Processed in 0.024882 second(s), 8 queries , Gzip On, Redis On.
