查看: 12032|回复: 2
[原创] Help on Spartan6 FPGA IO Standard Constrain
发表于 2011-4-17 21:44:23 | 显示全部楼层 |阅读模式
Hi, all,
  Recently I designed a DDR3(x4 mode, dual rank RDIMM) controller, and verified it on spartan6-lx150t-2fgg676.
The VDD of DDR3 interface is 1.5V power supplied. I used "SSTL2_II" io standard to constrain the DDR3 bus.
But when I changed io standard to "SSTL15_II", the ISE tool indicated that "SSTL15_II" is not supplied.
  Can anyone explain why SSTL15_II occurs error ?
  Thanks in advanced.
发表于 2011-4-17 22:36:04 | 显示全部楼层
回复 1# lik0604
    You can refer to Spartan 6 IO use guide to get valid IO standard for DDR3, this error report indicates this device/the IO bank can not support IO standard of SSTL15_II.
 楼主| 发表于 2011-4-18 11:33:00 | 显示全部楼层
OK, I'll try it.
GMT+8, 2025-10-30 04:47 , Processed in 0.015842 second(s), 6 queries , Gzip On, Redis On.
