查看: 13204|回复: 9
[讨论] 为嘛电路图和版图的PD AD PS AS等等不一样,也能通过LVS?
发表于 2011-4-17 20:12:47 | 显示全部楼层 |阅读模式
请教:为嘛电路图和版图的PD AD PS AS等等不一样,也能通过LVS?
不一样的话,貌似后仿真就不一样了。。
发表于 2011-4-18 06:58:45 | 显示全部楼层
AS AD PS PD are the parameters for the parasitics.
When schematics are captured, these parameters (i.e., AD, AS, PD & PS) are not given.
It is OK (allowed) the netlist for LVS does not contain these parameters.
Under such circumstances, the physical layout verification tool only check if the primary parameters match (between database from netlist and database converted from layout).
Parasitic information is only extracted during the parasitic extraction flow.
 楼主| 发表于 2011-4-18 09:03:36 | 显示全部楼层
回复 2# fhchen2002
    谢谢回答啊!
我还想问一下,要是这些参数不一样,仿真结果会有差别吗?我觉得应该没有差别吧,关键参数不是这些,不知道您是怎么看的?
发表于 2011-4-19 19:22:00 | 显示全部楼层
For high-frequency / high-speed circuits, the parasitics make simulation results a lot different.
For the simulation of ESD and I/O cells, since the drain-side layout is subject to ESD design rule, the parasitcs make a lot differences, too.
Without the correct AS, AD, PS, PD, the calculation of diode capacitance are much smaller.
For HV ESD cells, the drain-side RS and RD significantly increase the total RDS(ON).
发表于 2012-4-25 22:52:09 | 显示全部楼层
回复 2# fhchen2002
    请问一下,AD AS PD PS 各自代表什么寄生参数? 谢谢!
发表于 2012-4-25 22:59:51 | 显示全部楼层
care the match
 楼主| 发表于 2012-4-26 10:01:35 | 显示全部楼层
回复 5# sxzong_hit
    S端D端的面积和周长
发表于 2012-4-26 21:19:27 | 显示全部楼层
回复 7# lifusu
    谢谢!
发表于 2012-4-27 11:48:00 | 显示全部楼层
回复 5# sxzong_hit
AD: Area of Drain
AS: Area of Source
PD: Perimeter of Drain
PS: Perimeter of Source
NRD: Number of squares of Drain
NRS: Number of squares of Source, ... and a lot more. ...)
发表于 2019-8-21 14:36:59 | 显示全部楼层
Fo ...
您好,如何抽取AS AD PS PD 这些参数呢
GMT+8, 2025-12-24 17:03 , Processed in 0.024517 second(s), 6 queries , Gzip On, Redis On.
