查看: 7113|回复: 5
[讨论] 寄生参数提取后,如何反标到原理图中,进行直观分析?
发表于 2011-4-14 15:30:04 | 显示全部楼层 |阅读模式
用calibre提取了寄生参数,calibreview,寄生很大,而且寄生的管子、电阻、电容都被列在底下,不能很好分析。我想把这些寄生反过来标注在原理图中进行分析,有人知道吗??
谢谢啦!!
发表于 2011-4-14 20:18:14 | 显示全部楼层
I am not sure you can do that. As an alternative, try to extract cap you are interested in using awk
发表于 2011-4-14 21:57:56 | 显示全部楼层
我觉得这想法行不通
发表于 2011-4-15 12:56:19 | 显示全部楼层
不好搞啊!
发表于 2011-4-18 14:38:58 | 显示全部楼层
Please use the flow command to capture the parasitical capactior of your interesting net:
grep AAA XXX.spf | grep "^[cC]" | awk '{printf "%-10s %30s %30s %20s\n",$1,$2,$3,$4}'
AAA is the net name you interested in
XXX.spf is the LPE netlist with parasitical capacitor or resistor
cC is the keyword of capacitor or resistor
发表于 2011-4-21 17:17:35 | 显示全部楼层
宝宝,用assura才可以,calibre不得行哦。
GMT+8, 2025-11-23 03:05 , Processed in 0.018047 second(s), 6 queries , Gzip On, Redis On.
