查看: 5836|回复: 15
[原创] A switched capacitor DC DC converter for LDO replacement in 45nm CMOS
发表于 2011-4-11 14:06:31 | 显示全部楼层 |阅读模式
Title: A 0.16mm2 completely on-chip switched-capacitor DC-DC converter using digital capacitance modulation for LDO replacement in 45nm CMOS
Author: Ramadass, Yogesh; Fayed, Ayman; Haroun, Baher; Chandrakasan, Anantha P.
Department: Massachusetts Institute of Technology. Dept. of Electrical Engineering and Computer Science; Massachusetts Institute of Technology. Microsystems Technology Laboratories
Publisher: Institute of Electrical and Electronic Engineers
Issue Date: 2010-02
Abstract: A completely on-chip switched-capacitor DC-DC converter that occupies 0.16 mm2 [mm superscript 2] is implemented in a 45 nm CMOS process. The converter delivers 8 mA output current while maintaining load voltages from 0.8 to 1 V from a 1.8 V input supply. A digital capacitive modulation scheme is employed to maintain the converter efficiency between 50 to 70% over a wide range of load current levels.
Other Identifiers: INSPEC Accession Number: 11204884
ISBN: 978-1-4244-6033-5
ISSN: 0193-6530
Citation: Ramadass, Y. et al. “A 0.16mm2 completely on-chip switched-capacitor DC-DC converter using digital capacitance modulation for LDO replacement in 45nm CMOS.” Solid-State Circuits Conference Digest of Technical Papers (ISSCC), 2010 IEEE International. 2010. 208-209. © 2010, IEEE
Version: Final published version
Terms of Use: Article is made available in accordance with the publisher's policy and may be subject to US copyright law. Please refer to the publisher's site for terms of use.
Journal: IEEE International Solid-State Circuits Conference.. Digest of technical papers
abbr_76727a43ffb177e5d4bd06b54f1a324d.pdf
7.18 MB, 下载次数: 293 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2011-4-12 15:08:11 | 显示全部楼层
发表于 2011-4-20 13:47:58 | 显示全部楼层
thanks
发表于 2011-4-20 14:58:14 | 显示全部楼层
谢谢!!!
发表于 2011-9-3 09:16:07 | 显示全部楼层
Thanks for sharing!
发表于 2011-12-5 13:18:14 | 显示全部楼层
good book
发表于 2012-12-4 01:18:25 | 显示全部楼层
gfdgdfgdfgfgfgfgfgdf
发表于 2012-12-29 23:47:24 | 显示全部楼层
excellent topic..
发表于 2013-2-9 21:28:00 | 显示全部楼层
保持良好的工作............
发表于 2013-2-11 20:03:29 | 显示全部楼层
GMT+8, 2025-12-26 16:42 , Processed in 0.020226 second(s), 4 queries , Gzip On, Redis On.
