查看: 14527|回复: 16
[求助] ICC power设置
发表于 2011-3-17 17:10:19 | 显示全部楼层 |阅读模式
大家好。我把encounter中画好的的版图通过def读入到ICC里准备做功耗分析,版图能正确读入并显示。
但是当save_cell,或分析功耗时ICC会报告:Information: Performing CEL netlist consistency check. (MWDC-118)
Error: Non-PG pin VSS (0x7d2963) is driving PG net VSS (0x1cb4802). (MWDC-200)
Error: Non-PG pin VSS (0x7d2962) is driving PG net VSS (0x1cb4802). (MWDC-200)
Error: Non-PG pin VSS (0x7d2961) is driving PG net VSS (0x1cb4802). (MWDC-200)
Error: Non-PG pin VSS (0x7d2960) is driving PG net VSS (0x1cb4802). (MWDC-200)
Error: Non-PG pin VSS (0x7d295f) is driving PG net VSS (0x1cb4802). (MWDC-200)
Error: Non-PG pin VSS (0x7d295e) is driving PG net VSS (0x1cb4802). (MWDC-200)
Error: Non-PG pin VSS (0x7d295d) is driving PG net VSS (0x1cb4802). (MWDC-200)
Error: Non-PG pin VSS (0x7d295b) is driving PG net VSS (0x1cb4802). (MWDC-200)
Error: Non-PG pin VSS (0x7d2964) is driving PG net VSS (0x1cb4802). (MWDC-200)
Error: Non-PG pin VDD (0x7d296b) is driving PG net VDD (0x7c2082). (MWDC-200)
Error: Non-PG pin VDD (0x7d296a) is driving PG net VDD (0x7c2082). (MWDC-200)
Error: Non-PG pin VDD (0x7d2969) is driving PG net VDD (0x7c2082). (MWDC-200)
Error: Non-PG pin VDD (0x7d2968) is driving PG net VDD (0x7c2082). (MWDC-200)
Error: Non-PG pin VDD (0x7d2967) is driving PG net VDD (0x7c2082). (MWDC-200)
Error: Non-PG pin VDD (0x7d2966) is driving PG net VDD (0x7c2082). (MWDC-200)
Error: Non-PG pin VDD (0x7d2965) is driving PG net VDD (0x7c2082). (MWDC-200)
Error: Non-PG pin VDD (0x7d295c) is driving PG net VDD (0x7c2082). (MWDC-200)
Error: Non-PG pin VDD (0x7d296c) is driving PG net VDD (0x7c2082). (MWDC-200)
Error: Non-PG pin VSS (0x7d295d) is driving PG net VSS (0x7d6105). (MWDC-200)
Error: Non-PG pin VSS (0x7d295e) is driving PG net VSS (0x7d6105). (MWDC-200)
Error: Non-PG pin VSS (0x7d295f) is driving PG net VSS (0x7d6105). (MWDC-200)
Error: Non-PG pin VSS (0x7d2960) is driving PG net VSS (0x7d6105). (MWDC-200)
Error: Non-PG pin VSS (0x7d2961) is driving PG net VSS (0x7d6105). (MWDC-200)
Error: Non-PG pin VSS (0x7d2962) is driving PG net VSS (0x7d6105). (MWDC-200)
Error: Non-PG pin VSS (0x7d2963) is driving PG net VSS (0x7d6105). (MWDC-200)
Error: Non-PG pin VSS (0x7d2964) is driving PG net VSS (0x7d6105). (MWDC-200)
Error: Non-PG pin VDD (0x7d2965) is driving PG net VDD (0x7d6106). (MWDC-200)
Error: Non-PG pin VDD (0x7d2966) is driving PG net VDD (0x7d6106). (MWDC-200)
Error: Non-PG pin VDD (0x7d2967) is driving PG net VDD (0x7d6106). (MWDC-200)
Error: Non-PG pin VDD (0x7d2968) is driving PG net VDD (0x7d6106). (MWDC-200)
Error: Non-PG pin VDD (0x7d2969) is driving PG net VDD (0x7d6106). (MWDC-200)
Error: Non-PG pin VDD (0x7d296a) is driving PG net VDD (0x7d6106). (MWDC-200)
Error: Non-PG pin VDD (0x7d296b) is driving PG net VDD (0x7d6106). (MWDC-200)
Error: Non-PG pin VDD (0x7d296c) is driving PG net VDD (0x7d6106). (MWDC-200)
Error: Non-PG pin VSS (0x7d295b) is driving PG net VSS (0x7d6105). (MWDC-200)
Error: Non-PG pin VDD (0x7d295c) is driving PG net VDD (0x7d6106). (MWDC-200)
Error: CEL consistency check failed. (MWDC-100)
不知道是什么问题????????????????????
 楼主| 发表于 2011-3-18 08:49:30 | 显示全部楼层
发表于 2011-3-18 12:50:32 | 显示全部楼层
ICC 没有正确识别power pin/net 相关信息
建议检查def里面关于special nets的信息,  icc读def是经常容易出问题的,
还有derive_pg_connection  可以用下,
 楼主| 发表于 2011-3-21 11:39:27 | 显示全部楼层
QQ截图未命名.jpg 回复 3# icfbicfb
    又是icfbicfb,恩人呀!!!!
我检查了一下我ICC的版图,发现IO pad、cell 的位置、连线等都没有问题,但是所有的port信号都在左下角的一个方框里重叠放着(图片中所示) ,找了一些命令可以吧这些port放到IO pad上,但是这些命令会移动IO pad或者是芯片内部cell的place。以前是用encounter的,ICC很不熟练呀。。。
发表于 2011-3-21 15:17:14 | 显示全部楼层
只要 initialize_floorplan   就可以了啊,
也就是port是 unplace的状态,  如果是cell 聚在左下(中间也可能)起也是unplace状态,一个意思,
这个可能就是  icc 对def 处理的一些问题,  没办法, 读进来要仔细处理,
发表于 2011-3-21 15:22:55 | 显示全部楼层
用initialize_floorplan的话岂不是会重新进行floorplan 那encounter做的不就没用了?
回复 支持 0 反对 1
发表于 2011-3-21 15:31:13 | 显示全部楼层
顺便问下 在PNS或PNA中怎样使用本身的pad而不用create virtual power pad
发表于 2011-3-21 16:37:33 | 显示全部楼层
指定power source为本身的 pad就行了吧,
那个initialize_floorplan的事情:
可以keep_macro place  ,
实在不行只能写脚本 把port挪到 pad的位置了,
是set_port_location 吧,
很奇怪,为啥encounter做了 到icc里面做power分析啊, encounter自己有voltagestorm啊
发表于 2011-3-21 19:17:48 | 显示全部楼层
可以keep_macro place  ,  ...
icfbicfb 发表于 2011-3-21 16:37
    这不是voltagestorm没license么
请详解下
谢谢~
发表于 2011-3-23 16:09:10 | 显示全部楼层
求指导~
GMT+8, 2025-12-28 14:31 , Processed in 0.023849 second(s), 7 queries , Gzip On, Redis On.
