楼主: waynb
[求助] ICC power设置
发表于 2011-4-14 16:31:28 | 显示全部楼层
1. 先查有没有PORT VDD,VSS.
icc_shell> get_ports -all VDD
icc_shell> get_ports -all VSS
2. 如果没有:
create_port VDD -dir inout
create_port VSS  -dir inout
connect_net [get_nets -all VDD] [get_ports -all VDD]
connect_net [get_nets -all VSS] [get_ports -all VSS]
发表于 2013-12-27 16:09:30 | 显示全部楼层
回复 8# icfbicfb
  请问一下版主,我的VDD,GND的port也跑到左下角,应该就是unplaced的状态了,然后我用您说的命令却说找不着,但是版图上有port的说,网表上面也有。
icc_shell> set_port_location -coordinate {792.508 -0.500} -layer_name M1    -append  {VDD}
Warning: Can't find port 'VDD' in design 'design_top'. (UID-95)
Error: Value for list 'port_name' must have 1 elements. (CMD-036)
0
{VDD}
发表于 2014-4-5 13:02:49 | 显示全部楼层
Good job
发表于 2014-6-25 17:56:35 | 显示全部楼层
试一试将pad fix住,看行不行
发表于 2017-8-5 03:40:05 | 显示全部楼层
回复 12# 白兰地
     how to hand place IO pad cells in ICC design planning,I tried reading in the design.DEF with pre-defined locations in component section
but did not work
please help
发表于 2018-5-6 21:52:43 | 显示全部楼层
感谢大神回复!
发表于 2019-4-3 15:19:46 | 显示全部楼层
谢谢,收益匪浅
GMT+8, 2025-12-22 00:58 , Processed in 0.033968 second(s), 3 queries , Gzip On, Redis On.
