查看: 6699|回复: 6
[求助] 套筒式结构运放为什么很难使输入和输出短接
发表于 2011-3-12 17:18:03 | 显示全部楼层 |阅读模式
大家好,套筒式结构运放为什么很难使输入和输出短接,谢谢!
发表于 2011-3-12 18:17:37 | 显示全部楼层
    Generally, telescopic opamp Input CM range is too small to cover telescopic opamp Output Signal range (including CM+DM components)。Once output signal range exceed telescopic opamp Input CM range,the performance (eg. gain/bandwith) of telescopic opamp will degrade.
     However, in case  that the input signal is a DC voltage level and within the Input CM range of telescopic opamp, the input and output terminals of telescopic opamp can be connected directlty to configure a non-inverting gain (=1) amplifier/buffer.
发表于 2011-3-12 21:14:58 | 显示全部楼层
因为输入共模点的问题
发表于 2011-3-12 21:26:36 | 显示全部楼层
这书上不是说的很明白吗
 楼主| 发表于 2011-3-13 19:10:46 | 显示全部楼层
明白了,谢谢大家的解答
发表于 2011-3-14 14:55:43 | 显示全部楼层
overlap of input and output range is little
发表于 2011-3-28 11:26:09 | 显示全部楼层
学习了.
GMT+8, 2025-12-27 15:05 , Processed in 0.467851 second(s), 5 queries , Gzip On, Redis On.
