查看: 2805|回复: 1
[招聘] Senior SerDes Analog IC Design Engineer-上海
发表于 2011-3-3 13:47:18 | 显示全部楼层 |阅读模式
Position: Senior SerDes Analog IC Design Engineer
Position Description
Responsible for the design and development of SerDes analog/mixed signal IC circuit blocks from initial concept and specification through final verification and conformance to customer requirements.
Position Requirements
Bachelor or master degree in Electronics Engineering and related majors, PHD is preferred.
Minimum 5 years industry experience in CMOS SerDes IC design
Experience in SerDes transceiver designs including some of the following circuit blocks: System level modeling by matlab, C, or VerilogA; Driver; Receiver; Serializer; Deserializer; Phase Interpolator; Low jitter PLL; High Speed Clock Distribution; Bias and Bandgap and Voltage Regulators.
Good knowledge of a set of common SerDes standards and their electrical requirements, and a thorough understanding of jitter.
Proficient in using CAD tools for circuit simulation, layout, and physical verification (Cadence tool experience, lab test experience, and experience at 65nm and below technologies are a plus).
Good in problem solving and communication.
Ability to work cooperatively in team environment.
Annabel hunter
MSN 和邮箱  goodmorningliujing@163.com
如果你感兴趣,我会及时和你沟通信息。
发表于 2011-9-7 09:59:35 | 显示全部楼层
回复 1# annabelliu
    good!!
GMT+8, 2025-12-15 00:26 , Processed in 0.021660 second(s), 6 queries , Gzip On, Redis On.
