查看: 3611|回复: 5
[求助] 各位大神,求教ETS81的license方法
发表于 2011-2-24 17:42:14 | 显示全部楼层 |阅读模式
现在实验室有ETS72,但是里面没有想用的ELC,所以安装了ETS81,但是license不支持81的,请问如何解决问题,谢谢
发表于 2011-2-24 18:24:36 | 显示全部楼层
ding            ........
 楼主| 发表于 2011-2-24 22:23:33 | 显示全部楼层
license已经制备好了,并且可以正常checkout,但是怎么还是显示错误呢
[root@WWk bin]# elc
22:17:15 (cdslmd) OUT: "Encounter_Library_Char_GXL" root@WWk
22:17:15 (cdslmd) IN: "Encounter_Library_Char_GXL" root@WWk
22:17:15 (cdslmd) OUT: "Encounter_Library_Char_XL" root@WWk
22:17:15 (cdslmd) IN: "Encounter_Library_Char_XL" root@WWk
22:17:15 (cdslmd) OUT: "Encounter_Timing_System_GXL" root@WWk
22:17:15 (cdslmd) IN: "Encounter_Timing_System_GXL" root@WWk
22:17:15 (cdslmd) OUT: "Encounter_Timing_System_XL" root@WWk
22:17:15 (cdslmd) IN: "Encounter_Timing_System_XL" root@WWk
22:17:15 (cdslmd) OUT: "Encounter_Timing_System_L" root@WWk
22:17:15 (cdslmd) IN: "Encounter_Timing_System_L" root@WWk
ERROR: Fail to get license
Memory : 0.18M
Time   : 0.03 (user), 0.07 (sys), 0.10 (cpu), 0.47 (real)
 楼主| 发表于 2011-2-26 13:29:20 | 显示全部楼层
自己封贴 找到办法了
发表于 2012-10-11 14:23:37 | 显示全部楼层
楼主你好,ETS8.1安装文件,挺长时间都没有找到~能发一份吗?谢谢~
发表于 2012-10-11 14:25:14 | 显示全部楼层
我的邮箱:aaaxyzboy@163.com,谢谢了~
GMT+8, 2025-12-25 17:19 , Processed in 0.026694 second(s), 6 queries , Gzip On, Redis On.
